Home > Forums > Visualization & Post-Processing Software > Tecplot
Avoid Mesh Triangulation in Slices
Old   February 11, 2015, 13:55
Default Avoid Mesh Triangulation in Slices
Lukas
luhawk is on a distinguished road
Hello all,
I want to use Tecplot to visualize my mesh in a slice. It is a Hexmesh so this should result in rectangles in the slice. However, Tecplot always triangulates the Mesh in the slice so there is only triangles. Interesting because on surfaces it does't do that. Is there any option to turn of mesh triangulation in slices like in paraview 4.1?
Any help is appreciated.
Best
luhawk is offline   Reply With Quote
Old   February 12, 2015, 20:42
Default Known limitation in Tecplot 360 / 360 EX
Durrell Rittenberg
Durrell4 is on a distinguished road
Send a message via MSN to Durrell4 Send a message via Yahoo to Durrell4 Send a message via Skype™ to Durrell4
Hi Luhawk,
We are aware of this limitation and are planning on addressing it later this year time permitting. Are you interested slicing where you see the cell faces sometime referred to as a crinkle surface?
Best
Durrell
Durrell4 is offline   Reply With Quote
[ICEM] Mirror Mesh | Delete duplicate mesh pythag0ra5 ANSYS Meshing & Geometry 6 November 19, 2013 07:35
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
How avoid two surfaces's mesh stacking up? ? Rockda ANSYS Meshing & Geometry 0 September 5, 2011 05:14
engrid -> save as .stl with boundarie codes Zymon enGrid 31 August 29, 2011 13:40
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
