hi, I have simulated flow past a circular cylinder and I have used Tecplot to visualize vorticity contours. I have inserted the circular geometry using default option in tecplot. When exporting my plot into EPS format, the circular geometry is not coming and contours are coming; but in WMF and JPEG formats geometry also is coming. Is there anything to be done while exporting a plot into EPS format? Thank you..
Fix the cylinder to the zone and then export.It would work fine.
Reading Additional Data Quantities from Fluent into Tecplot | fremder | Tecplot | 9 | December 16, 2016 15:35 |
Importing contour maps into Tecplot | jcostex | Tecplot | 1 | May 20, 2009 12:48 |
How to read tecplot file witout tecplot ? | Pol | Tecplot | 11 | March 2, 2007 06:26 |
Using Tecplot for contours display | david | FLUENT | 2 | August 23, 2005 22:37 |
Tecplot can't read data file from Fluent. | stephen | FLUENT | 8 | November 21, 2001 20:27 |
