January 12, 2017, 09:42 |
variable definition
ram
Rep Power: 13 |
I am trying to draw a curve of temperature during 24 hours of a day. So, I have to define X axes from 6 (6 am) to 23, next 0 (24 pm), 1, 2, ..., 5 (5 am of the next day). How can I define X axes like that in Tecplot? It should be like this: 6,7,8,...,23,0,1,2,3,4,5 |
February 1, 2017, 19:39 |
Scott Fowler
Rep Power: 17 |
To do this you can include a CUSTOMLABEL record in an ASCII data file.
Below is an example ASCII (.dat) file with a CUSTOMLABEL record. In this case "6" will correspond with 0, "7" with 1, etc. Tecplot 360 will repeat the pattern beyond the end. Custom labels are not displayed for negative data values. Then in the Axis Details dialog on the Labels page click on the Number Format button and select Custom in the drop down menu. TITLE = "Grid" VARIABLES = "X" "Y" CUSTOMLABELS = "6" "7" "8" "9" "10" "11" "12" "13" "14" "15" "16" "17" "18" "19" "20" "21" "22" "23" "0" "1" "2" "3" "4" "5" ZONE T="1-D Zone" STRANDID=0, SOLUTIONTIME=0 I=24, J=1, K=1, ZONETYPE=Ordered DATAPACKING=POINT DT=(SINGLE SINGLE ) 0.000000000E+000 1.000000000E+000 1.086956501E+000 1.000000000E+000 2.173913002E+000 1.000000000E+000 3.260869503E+000 1.000000000E+000 4.347826004E+000 1.000000000E+000 5.434782505E+000 1.000000000E+000 6.521739006E+000 1.000000000E+000 7.608695507E+000 1.000000000E+000 8.695652008E+000 1.000000000E+000 9.782608986E+000 1.000000000E+000 1.086956501E+001 1.000000000E+000 1.195652199E+001 1.000000000E+000 1.304347801E+001 1.000000000E+000 1.413043499E+001 1.000000000E+000 1.521739101E+001 1.000000000E+000 1.630434799E+001 1.000000000E+000 1.739130402E+001 1.000000000E+000 1.847826004E+001 1.000000000E+000 1.956521797E+001 1.000000000E+000 2.065217400E+001 1.000000000E+000 2.173913002E+001 1.000000000E+000 2.282608604E+001 1.000000000E+000 2.391304398E+001 1.000000000E+000 2.500000000E+001 1.000000000E+000 Hope that helps, Scott |
Variable name for heat flux | peterle | CFX | 4 | February 13, 2014 02:21 |
Instalation on ubuntu 710 | basilwatson | OpenFOAM Installation | 17 | March 16, 2012 20:16 |
Additional variable as output of an expression | Chander | CFX | 1 | November 22, 2011 12:54 |
Additional Variable | tav98f | CFX | 3 | April 28, 2011 12:33 |
Question about making a variable function of proprities of onother variable ? | rafiktharwat | CFX | 0 | March 26, 2011 14:23 |
