Home > Forums > Visualization & Post-Processing Software > Tecplot
Tecplot Problem
Old   February 13, 2001, 20:34
Default Tecplot Problem
Mike
I have met a problem with tecplot. When I use "specify equations" to define new variables(in two dimension plot), I found function"ddx" and "ddy" work while "ddz" doesn't work. Only "ddz" function always reply with error message. For example, When typing " {a}=ddz({v}) ", the error message shows it as " {a}=ddz|({v}) ". Does anyone know how to use "ddz"? I appreciate your help.
Old   February 13, 2001, 21:53
Default Re: Tecplot Problem
C. Lei
I think in two dimensional plots, you can only have ddx() and ddy() since ddz() is defined for three dimensional plots.
Good luck.
[Commercial meshers] Handling cyclic BC from gambit to openfoam for a cascade airfoil problem - OF 1.6 maverick OpenFOAM Meshing & Mesh Conversion 2 June 18, 2011 04:36
Velocity profiles problem behind the elbow (3D problem) kabat73 FLUENT 8 May 9, 2010 04:26
Using Tecplot for contours display david FLUENT 2 August 23, 2005 22:37
A tecplot problem scubme FLUENT 2 November 22, 2004 04:43
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
