Home > Forums > Visualization & Post-Processing Software > Tecplot
A tecplot problem
Old   November 21, 2004, 23:31
Default A tecplot problem
scubme
Hi All My model is a pipe flow, and the viscosity of fluid is variable in the flow field. The iteration had been processed in Fluent. Now I want to show the distribution of fluid viscosity, if which is larger than a constant value. At same time, I also want to show transparently the outline of the pipe wall. But I don't know how to show this two effects at one time. Pls someone give me any advices.
[Commercial meshers] Handling cyclic BC from gambit to openfoam for a cascade airfoil problem - OF 1.6 maverick OpenFOAM Meshing & Mesh Conversion 2 June 18, 2011 04:36
Velocity profiles problem behind the elbow (3D problem) kabat73 FLUENT 8 May 9, 2010 04:26
Using Tecplot for contours display david FLUENT 2 August 23, 2005 22:37
A tecplot problem scubme FLUENT 2 November 22, 2004 04:43
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
