July 15, 2011, 13:56 |
schlieren output
Mohan
Rep Power: 15 |
Hi
How is it possible to get a Schlieren type image output using Tecplot? (I've checked the archives...though a few have asked this question, they have gone unanswered) Thank you |
July 15, 2011, 18:19 |
Scott Rumage
Rep Power: 17 |
Tecplot 360 can make a “simulated” Schlieren via flooded contours of the density magnitude. Image #7 on this link gives an example: http://www.tecplot.com/Community/PlotGallery/2DPlots.aspx
BTW - a Shawdowgraph is calculated via the 360 menu bar: Analyze>>Calculate Variables>>Shawdowgraph (but I did not find the Schlieren calculation referenced in the above link). I hope this is of some help. Scott |
July 16, 2011, 19:11 |
Mohan
Rep Power: 15 |
Thanks Scott, that was actually helpful. That'll be something I'll be needing too!
I'm trying to experiment with the density related variables to give me a Schlieren type image at the moment. |
July 16, 2011, 19:53 |
Mohan
Rep Power: 15 |
January 8, 2013, 04:50 |
Rep Power: 13 |
A Sch. image is due to the density gradient if memory serves me right. Therefore you need to use the same thing in the code. This is what I do: 1) Go to data -> alter equations 2) make two variables {rx}=ddx(V01) and {ry}=ddy(V01) where V01 is the density. 3) make a variable {sch} = ({rx}**2+{ry}**2)**0.5 4) Plot contours of {sch} Often I find I need to change the cutoffs and ranges to bring out the detail, choose grayscale and for some reason inverting it always seems nicer but that might just be my case. Hope this helps. Mike |
October 6, 2014, 18:19 |
hamid
Rep Power: 12 |
hi,
i have recently got my schlieren type image using tecplot but my problem is here that the resolution of the created image is so low. in order to be sure that the procedure i've done to create my schlieren type image is correct, i wanted to know what kinds of variables should we use to plot a schlieren type image? and whether it should be as a contour or a shadowgraph? thank you very much |
October 7, 2014, 09:06 |
Image Resolution
Hi Moezzi,
Are you setting the contour variable to the Shadograph? Set the values to -1000 to 1000 or -100 to 100 and set the coloring to continuous and the colormap to gray-scale. This should get you to the image you are looking for if not here are two possible things going on here. It is possible that the resolution of the data is such that the contours appear jagged. If that is the case then you can try interpolation on to a finer grid which can help with the contour levels. In this case the exported image will have the same artifacts as the plot in Tecplot. If the image output resolution is the issue you can control that from the export dialog file>Export From the export dialog select export format > PNG Select: Enter width: use a value over 1500 Select: Antialiasing and accept the default. More information available here and here let me know how it works out Last edited by Durrell4; October 7, 2014 at 09:16. Reason: forgot a key peice |
October 27, 2014, 13:29 |
Tecplot Tutorial on Shadowgraph calculations
Hi all,
I have posted a quick tutorial on using shadowgraphs in Tecplot. http://www.tecplot.com/blog/2014/10/...ity-gradients/ Hope this helps. Durrell |
Questions about data output | aki_yafuji | OpenFOAM Running, Solving & CFD | 3 | September 9, 2010 01:59 |
lift and drag on ship superstructures | vaina74 | OpenFOAM Running, Solving & CFD | 3 | June 8, 2010 12:30 |
Output transient file to csv | Ben | CFX | 3 | September 23, 2008 08:17 |
[Other] Output Format of MetaMesh | t42 | OpenFOAM Meshing & Mesh Conversion | 0 | August 3, 2007 04:28 |
Help with DPM UDF for OUTPUT needed | Zhengcai Ye | FLUENT | 0 | January 5, 2004 16:58 |
