MODAL Validation in FSI study on AGARD 445.6 wing
Old   December 11, 2018, 01:09
Default MODAL Validation in FSI study on AGARD 445.6 wing
Zeeshan Khan
zeeshan khan is on a distinguished road
Send a message via Skype™ to zeeshan khan
I am trying to validate modal frequency of Argad 445.6 wing. The test model used in the experiments(Yates Jr 1987) was constructed by laminated mahogany, which has different material properties in each direction. The material properties in each direction for this weakened AGARD 445.6 wing is given below , where E is the Elasticity Modulus, G is Shear modulus and ρ
is density.
E11 3.1511GPa
E22 0.41621GPa
E33 0.41621GPa
ν12 0.31
ν13 0.31
ν23 0.31
G12 0.4392 GPa
G23 0.4392 GPa
G13 0.4392 GPa
ρ 397 kg/.
the above data have been taken from a research papers and cross checked whith several other papers related to Agard wing modal validation.Also the cad model is crosschecked and found NO problems in that .Now i have created custom material for the purpose defining density , and linear orthotropic elasticity (snap is attached)in ansys Engineering data tabe. the problem is modal frequency calculated with modal is about half of the values given in the paper i am following (i am attaching one of the paper for convenience ) . I am trying to solve the said problem from about 5 weeks , but failed to figure out the reason. i am very exhausted due to this. If some body could help me i will be very thankful to him/her.
Attachments.
https://drive.google.com/open?id=1H7...-x6s_GSEYjb3qH
https://drive.google.com/open?id=1wO...duAQjIys5BfZlY
https://drive.google.com/open?id=1RP...2QEt0vBvRIHtHh
https://drive.google.com/open?id=1tV...9KKyQvMIoeITGo
Last edited by zeeshan khan; December 14, 2018 at 02:50. Reason: attachment was not opening
zeeshan khan is offline   Reply With Quote
Old   December 14, 2018, 03:03
Zeeshan Khan
Any body there?? please help me, i am stuck from about a month in this problem....
Old   October 4, 2022, 12:24
Doga
dogabeser is on a distinguished road
hi zeeshan,I'm having the same. Did you solve the problem?
dogabeser is offline   Reply With Quote
agard 445.6
Ffd_control_point_2d feiyi SU2 4 September 30, 2019 12:42
Wing FSI simulation: Shell elements or 3D solid body? frossi CFX 3 June 15, 2016 20:02
Some confusion in AGARD Wing 445.6 with FSI analysis Jordane Main CFD Forum 0 February 12, 2014 02:19
CFX-Pre problem, pls help!!! cth_yao CFX 0 February 17, 2012 00:52
Help for agard wing 445.6 structure mode data Qu Kun Main CFD Forum 0 October 29, 2008 21:16
