MODAL Validation in FSI study on AGARD 445.6 wing |
December 11, 2018, 01:09 |
I am trying to validate modal frequency of Argad 445.6 wing. The test model used in the experiments(Yates Jr 1987) was constructed by laminated mahogany, which has different material properties in each direction. The material properties in each direction for this weakened AGARD 445.6 wing is given below , where E is the Elasticity Modulus, G is Shear modulus and ρ
is density. E11 3.1511GPa E22 0.41621GPa E33 0.41621GPa ν12 0.31 ν13 0.31 ν23 0.31 G12 0.4392 GPa G23 0.4392 GPa G13 0.4392 GPa ρ 397 kg/. the above data have been taken from a research papers and cross checked whith several other papers related to Agard wing modal validation.Also the cad model is crosschecked and found NO problems in that .Now i have created custom material for the purpose defining density , and linear orthotropic elasticity (snap is attached)in ansys Engineering data tabe. the problem is modal frequency calculated with modal is about half of the values given in the paper i am following (i am attaching one of the paper for convenience ) . I am trying to solve the said problem from about 5 weeks , but failed to figure out the reason. i am very exhausted due to this. If some body could help me i will be very thankful to him/her. Attachments. https://drive.google.com/open?id=1H7...-x6s_GSEYjb3qH https://drive.google.com/open?id=1wO...duAQjIys5BfZlY https://drive.google.com/open?id=1RP...2QEt0vBvRIHtHh https://drive.google.com/open?id=1tV...9KKyQvMIoeITGo Last edited by zeeshan khan; December 14, 2018 at 02:50. Reason: attachment was not opening |
December 14, 2018, 03:03 |
Any body there?? please help me, i am stuck from about a month in this problem....
October 4, 2022, 12:24 |
Doga
hi zeeshan,I'm having the same. Did you solve the problem?
agard 445.6 |
Ffd_control_point_2d | feiyi | SU2 | 4 | September 30, 2019 12:42 |
Wing FSI simulation: Shell elements or 3D solid body? | frossi | CFX | 3 | June 15, 2016 20:02 |
Some confusion in AGARD Wing 445.6 with FSI analysis | Jordane | Main CFD Forum | 0 | February 12, 2014 02:19 |
CFX-Pre problem, pls help!!! | cth_yao | CFX | 0 | February 17, 2012 00:52 |
Help for agard wing 445.6 structure mode data | Qu Kun | Main CFD Forum | 0 | October 29, 2008 21:16 |
