Hexahedral mesh with CFX-Mesh
Old   March 5, 2007, 11:28
Default Hexahedral mesh with CFX-Mesh
isabel
Hi, everybody
I need to mesh a geometry with hexahedral elements. Can I do it in CFX-Mesh? I only can do it with triangles and quads.
Old   March 5, 2007, 13:50
Default Re: Hexahedral mesh with CFX-Mesh
Alex
In CFX-Mesh, you can technically create a structured mesh by extruding one face (i.e. surface mesh) out across the entire domain. This means for simple geometries such as a straight pipe, it can be done. For any more complicated geometries you will have trouble extruding the mesh properly and it will either fail or generate a poor mesh. See the documentation for info on extruding, or look into gridgen or another meshing package to generate more complex structured meshes.
Old   March 5, 2007, 15:37
deLuther
Why look for gridgen if ANSYS ICEM CFD is superior? And better suited to CFX...
Old   March 6, 2007, 05:24
Default Re: Hexahedral mesh.I don’t know if it is possib
isabel
Thanks for your advice
As you have said, I have created a structured mesh by extruding one face (extruding 2D mesh with option nº of layers = 1) but the problem is that I have what I want in only one direction. If I try to use inflation and extruding together, I only have a hexahedral mesh near the walls, not in all the geometry. Why? Is there any option to apply inflation to all the geometry?
Regards, Isabel
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
CFX Mesh Deformation problem Silmaril CFX 7 October 19, 2010 10:00
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
Mesh from ICEM CFD to CFX ! Error ! Why ? Thanks ! Vu Trinh Tuan CFX 11 March 28, 2005 19:04
importing mesh from ICEM CFD into CFX 5 Jay CFX 2 November 12, 2002 13:46
