Exporting Pressure data from FLUENT to ANSYS
Like Tree3Likes
  • 2 Post By Whats_in_a_name
  • 1 Post By ermes
Old   February 15, 2007, 00:21
Default Exporting Pressure data from FLUENT to ANSYS
Whats_in_a_name
Hi all,
I've just got the pressure distribution over a wing in FLUENT. I now need to structutrally analyze it in ANSYS.
I'm lookin to export the data from FLUENT to ANSYS. Any ideas and suggestions on how i can accomplish this are welcome.....
Thnx, Flyboy
hhzhangfuxing and pengxudong like this.
Old   February 15, 2007, 16:46
Default Re: Exporting Pressure data from FLUENT to ANSYS
Freeman
well, fluent normally has specific formats of files. it automatically create *.cas and *.dat which're acceptable to most software. Since you might already have these files, try to check your ansys package and see if you can 'import' fluent data. now, both are the same company, I think it should be possible. let me know if you're not able to do so.
take care
Old   February 19, 2007, 00:54
whats_in_a_name
Nope importing .cas or .dat files doesn't work and exporting data from Fluent to ANSYS's .rfl isn't working either (dont know why though, it's genrating 0 byte .rfl files). Sad they're both from the same company....
Thnx man 4 the suggestion, it was worth a try anyway.
Old   April 24, 2010, 07:32
Fred Pier
fredcab66 is on a distinguished road
I have the same problem , i would like to export pressure on my wing , to ansys , for a structural analyse.
My problem is a 2D problem , and my my mesh is 2D too.
So i want import in ansys pressure on one edge.
I use Workbench 2 , fluent , and ansys mecanical.
i have already try a lot of thing, but no result ! :-(
Have you sucess, if yes, could you explain me , how didi you do ?
Thanks
Fred
fredcab66 is offline   Reply With Quote
Old   April 24, 2010, 10:27
Randre is on a distinguished road
Do you have the new ANSYS version? 12.0 or 12.1? If you use standard FSI project schematic: FLUENT - TRANSIENT STRUCTURAL and connect them, the pressure distribution on the wing will be exported do ANSYS MECHANICAL. But I think that ANSYS mechanical will work only with a 3D wing.
Randre is offline   Reply With Quote
Old   April 26, 2010, 03:16
Fred Pier
Hello Randre, and everybody,
First , thanks for our answer.
I used Ansys 12.0.
I used a FSI projet : Cfd Fluent -> Static strutural.
When i 'am making this projet in 3D , all it's ok , the pressure distribution is imported from fluent to mechanical.
But my problem don't need to be in 3d, and my computer is not so performant.
That's why i want to solve this problem in 2D .
But in 2d i can't import pressure.
I have already tried :
using the workbench interface, connecting the Fluent's results to the Mechanical's steup.
And exporting the load from fluent in a .cdb file.
But no result
If you think that you can help me , do not hesitate !
Cheers !
fred
Old   May 14, 2010, 05:00
Unhappy Fsi
ermes is on a distinguished road
Hi all,
I'm trying to export pressure data from fluent to ansys to have a structural analisys but fluent export nodes and shell elements.
To make my strustural analisys i need to use brick elements so i don't know how to do.
Somebody can help me?
Thanks.
hhzhangfuxing likes this.
ermes is offline   Reply With Quote
Old   September 3, 2017, 03:09
Default Importing loads form FLUENT
Ujwal Rajan
ujwal rajan is on a distinguished road
Hey guys,
Hope you're all well.
Is there any way of importing pressure loads from fluent onto a structure for a 2D analysis??
When i try to import loads on the static structure module, there is a dialogue box that appears which indicates that pressure is being imported however, nothing seems to happen. I've given about 25 mins time and nothing seems to be happening.
If i try using system coupling, it says that FLUENT does not support system coupling for 2D cases.
Any help is massively appreciated.
Cheers!
Thank you
ujwal rajan is offline   Reply With Quote
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Exporting fluent case data to Ensight/paraview aerogt3 FLUENT 8 May 7, 2012 09:15
pressure inlet bc in fluent nikhil FLUENT 0 June 28, 2010 16:30
Exporting results from CFX to ANSYS ?? sohail ahmed CFX 1 December 20, 2007 01:10
Postprocessing Pressure data spanwise over a wing Rick FLUENT 1 February 3, 2006 09:28
