March 13, 2015, 08:52 |
Euler Euler Water Spray in air
Rep Power: 13 |
I want to simulate a spray of water in a chamber filled with air using the Eulerian model. Is there a solver in OpenFoam for this two-phase problem ? I would like to see the macroscopic behavior of the spray such as penetration depth and spread of the spray for different temperature and pressure of the air chamber. Thank you! |
March 16, 2015, 07:37 |
Rep Power: 13 |
bump
July 17, 2018, 07:49 |
#3 | |
Vivek
Rep Power: 8 |
August 6, 2018, 05:23 |
krishnan
Rep Power: 8 |
twoPhaseEulerFoam is the appropriate solver to use. It follows the eulerian eulerian approach for multiphase flows
August 6, 2018, 08:33 |
Vivek
Rep Power: 8 |
eulerian multiphase model, injection, spray modeling, two phase flow |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Mass Flow rate in spray water modeling | Behnam Ghadimi | FLUENT | 0 | June 8, 2013 16:05 |
Mass Flow rate in spray water modeling | Behnam Ghadimi | Main CFD Forum | 0 | June 8, 2013 15:48 |
I am NOT getting right pressure at the air inlet in water column | kcfd | FLUENT | 2 | November 27, 2012 21:36 |
I am NOT getting right pressure at the air inlet in water column | kcfd | FLUENT | 0 | November 24, 2012 23:14 |
