Euler Euler Water Spray in air
Like Tree1Likes
  • 1 Post By tankerp
Old   March 13, 2015, 08:52
Default Euler Euler Water Spray in air
shadowfax is on a distinguished road
I want to simulate a spray of water in a chamber filled with air using the Eulerian model. Is there a solver in OpenFoam for this two-phase problem ?
I would like to see the macroscopic behavior of the spray such as penetration depth and spread of the spray for different temperature and pressure of the air chamber.
Thank you!
shadowfax is offline   Reply With Quote
Old   March 16, 2015, 07:37
bump
Old   July 17, 2018, 07:49
Vivek
vivek05 is on a distinguished road
Thank you!
i am also working in same area of your posted question . if you got any answers to this question please let me know.
vivek05 is offline   Reply With Quote
Old   August 6, 2018, 05:23
krishnan
tankerp is on a distinguished road
twoPhaseEulerFoam is the appropriate solver to use. It follows the eulerian eulerian approach for multiphase flows
Jeneas likes this.
tankerp is offline   Reply With Quote
Old   August 6, 2018, 08:33
Vivek
Thank you krishnan!!
i am having one doubt. can twoPhaseEulerFoam capture the primary breakup zone in atomization process??
eulerian multiphase model, injection, spray modeling, two phase flow
Mass Flow rate in spray water modeling Behnam Ghadimi FLUENT 0 June 8, 2013 16:05
Mass Flow rate in spray water modeling Behnam Ghadimi Main CFD Forum 0 June 8, 2013 15:48
I am NOT getting right pressure at the air inlet in water column kcfd FLUENT 2 November 27, 2012 21:36
I am NOT getting right pressure at the air inlet in water column kcfd FLUENT 0 November 24, 2012 23:14
