Home > Forums > Mesh Generation & Pre-Processing Software > ANSA
layer mesh
Like Tree1Likes
  • 1 Post By vangelis
Old   August 30, 2013, 04:08
Question layer mesh
Jingyao Wang
wjy-c is on a distinguished road
hi, there!
i would like to have a layer mesh on the model surface and i used the ANSA 14.0.
according to command "Mesh-Volume-layer", at first i meshed a flat plane, and the layer mesh seems right. but when i try to mesh a gear model, the layer distribution is terrible.
the gear model i want to mesh is like this.
when using "layer", i took all the default parameter.
when the mesh is over, the volume turns out to be like this.
in the corner position, the mesh did not continue. moreover, the automesh seems hard to decide which direction the layer should be generate, which result the terrible mess.
i'm new to ANSA, after i read the ANSA help document, i still cannot figure out which parameter in layer should i change to get a better mesh. i cannot find any tutorials about this problem. so please tell me the correct process to get a better mesh, or maybe tell me where can i find some useful information. Thank you very much!
wjy-c is offline   Reply With Quote
Old   September 2, 2013, 06:09
Vangelis Skaperdas
vangelis is on a distinguished road
Hi
ANSA generates layers in the gray (postive) side of the surface mesh.
So in ENT and SHADOW mode your model must look gray on the outside
and yellow on the inside.
It seems your surface mesh has NON uniform orientation.
Use MACROs>ORIENT to assign uniform positive gray orientation to your
surface mesh and then generate the layers
hope this helps
Vangelis
mamama797979 likes this.
vangelis is offline   Reply With Quote
[ICEM] Hybrid mesh for 2D boundary layer Bigio ANSYS Meshing & Geometry 33 November 18, 2019 09:15
[snappyHexMesh] Boundary layer in a pipe Clementhuon OpenFOAM Meshing & Mesh Conversion 6 March 12, 2012 12:41
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
