[ICEM] Wrapping mesh around NACA0012
Like Tree1Likes
Old   May 12, 2012, 16:27
Post Wrapping mesh around NACA0012
James Hetfield is on a distinguished road
Hi
Does anyone know how to wrap a NACA0012 airfoil with boundary layer in ICEM?
James Hetfield is offline   Reply With Quote
Old   May 12, 2012, 16:29
I mean something like this
http://www.google.com/imgres?hl=en&b...9&tx=134&ty=79
Old   May 13, 2012, 01:46
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
either go for
1. the prism + tetra or
2. create two domain.
One for the structured mesh for boundary layer and other one for the outer domain with tetra and then merge them to form the continuous mesh. There is one tutorial on hybrid meshing in ICEM 11 tutorial guide.
Far is offline   Reply With Quote
Old   May 13, 2012, 13:56
Its about 5 months that Ive been trying to mesh 2D NACA 0012 airfoil but cant get convergence.
Im really stuck
Old   May 13, 2012, 14:10
Far
Sijal
Really
What you want to do, I can help you. Try ICEM hexa
Old   May 13, 2012, 14:21
I generate the grid exactly based on what Simon has said in the tutorial but it does not work for me
I sent u two emails. Id appreciate it if u take a look at my meshes
Old   May 13, 2012, 14:24
Far
Sijal
small mistake I just found.
Old   May 13, 2012, 14:29
I need the grid to be fine enough (first layer of the order of 10^-6 or 10^-7 normal to the airfoil surface) to get the correct drag coefficient
Old   May 13, 2012, 14:53
Whats the matter?
Old   May 13, 2012, 15:00
Far
Sijal
Whats the Reynolds no?
Old   May 13, 2012, 15:01
6 million
i wanna check my results with those in http://turbmodels.larc.nasa.gov/naca0012_val.html
Old   May 13, 2012, 16:00
Far
Sijal
check this mesh
Old   May 13, 2012, 16:08
should I change it (number of nodes and growth ratios) or just run it in FLUENT with these features?
Thanks man
Old   May 13, 2012, 16:11
Far
Sijal
Just output the mesh with appropriate boundary condition and run in Fluent. Tell me the yplus after 20-30 iterations
Old   May 13, 2012, 16:21
Yplus over airfoil surface after 25 iterations
Turbulence model: SST-KW
CFL = 5
Old   May 13, 2012, 16:24
Far
Sijal
good enough. proceed with simulation and compare results with experimental. use double precision.
Use hybrid initialization and solution steering
Old   May 13, 2012, 16:31
it doesnt converge and just oscillates
also, based on NASA website that I mentioned earlier, I think more nodes are needed on the airfoil surface
and more resolution is required near the trailing edge
ratio in the boundary layer must be less than 1.06 but here its 1.23
Old   May 13, 2012, 16:33
Far
Sijal
give CLF 0.1 and use 1st order scheme. Also start new topic in Fluent forum for further discussion.
Old   May 13, 2012, 16:35
Far
Sijal
give me boundary conditions, I try them here
Old   May 13, 2012, 16:36
ahh
this convergence is killing me
I cant get a mesh working
I dont know if i should switch to another mesher or solver
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 08:52
Converting Starccm+ mesh Ladnam OpenFOAM 0 September 14, 2011 06:30
Meshing aifoil in ICEM student123a ANSYS Meshing & Geometry 13 December 8, 2010 10:40
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
