[ICEM] what is the strategy to block this geometry?
Old   October 3, 2012, 09:10
Default what is the strategy to block this geometry?
Li
llrr is on a distinguished road
Hi everyone, I am learning ICEM CFD (v14.0) now. Can you help to see how I can get high quliaty mesh with this geometry? Thank you.
llrr is offline   Reply With Quote
Old   October 3, 2012, 09:47
cfd seeker is on a distinguished road
attach .tin file so that we can have a try on your geometry
cfd seeker is offline   Reply With Quote
Old   October 3, 2012, 12:27
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
initiliaze your blocling first. do two vertical split each one at the end of the deflectors.
same for horizontal split. because of deflector, you will need y-grid there. good luck.
Share your tin, i might take a look at it late at night...
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   October 4, 2012, 02:31
Li
Thank you guys, here is the tin file.
Old   October 4, 2012, 02:33
Li
I will also try it according diamondx's suggestion, thank you.
Old   October 4, 2012, 05:17
Li
Hi Diamondx and cfd seeker, I enclosed the picture to show the determinant and angle histogram (I was going to upload .blk file, but it is not allowed). I do not think the mesh quality is good especially when I look at the Angle histogram. Can you help me to see how I can improve it? Thank you.
File Type: jpg ph-exercise1-determinant historgram.jpg (97.0 KB, 55 views)
Old   October 4, 2012, 09:05
Stuart Buckingham
stuart23 will become famous soon enoughstuart23 will become famous soon enough
Hi llrr, try creating a zip archive of the files, then upload
stuart23 is offline   Reply With Quote
Old   October 5, 2012, 04:05
Li
Hi Stuart, thank you for the suggestions. Here it is.
Old   October 5, 2012, 13:36
diamondx's Avatar
Ghazlani M. Ali
sorry for not replying, i will take a look at it when i'll have time, i'm little bit busy... sorry again i hope you're not in a rush
Regards,
Ali
Old   October 7, 2012, 03:34
Li
Hi Diamondx, I appreciate your help. Take your time and I will also keep learning:-) Thank you.
Old   October 7, 2012, 03:39
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
tin file is missing
Far is offline   Reply With Quote
Old   October 7, 2012, 03:43
Li
Originally Posted by Far View Post
tin file is missing
Hi Far, Thank you for the information. I guess it is because I didn't found that I could not attach .tin file last time. Here is the .zip file of .tin. Thank you.
Old   October 7, 2012, 07:52
Far
Sijal
Here is the solution. Is this what you asked for?
Old   October 7, 2012, 08:40
Li
Hi Far, can you explian to me how you made the block? Thank you.
Old   October 7, 2012, 10:35
Far
Sijal
1. one horizontal split for the upper part. second and third split for the two inclined plates.
2. three vertical splits for the upper part.
3. Change the material of two blocks on the right and left side of upper part to dead.
4. Vertical splits for the inclined plates
5. associates edges and vertices
6. associate faces to part for four inclined plates.
Old   October 7, 2012, 13:18
Far
Sijal
This was really a very simple and basic blocking. No Y-block, or O-grid.
Old   October 7, 2012, 13:37
Li
Thank you very much for your help. I will study it carefully.
Old   October 8, 2012, 03:19
Li
Hi Far, I did what you told me and I made it. But when I open the window on the roof and I have a problem with the mesh quality again. Would you please help me to see it again what the problem is of my block? Enclosed please find the .tin and .blk file. Thank you.
Old   October 8, 2012, 03:24
Li
I tried to make a y-block at the wedge of the roof, but it looks not right. What did I do wrong?
Old   October 8, 2012, 06:17
Christoph
energy382 is on a distinguished road
you insert some new geometry, called roofwinwall. what's that?!
nevertheless, it's not a closed surface, so if you want to insert y-block, you've to insert additional surfaces.
energy382 is offline   Reply With Quote
[ICEM] blocking strategy for ellipse geometry gajemon ANSYS Meshing & Geometry 6 April 21, 2014 16:19
[ICEM] Copy geometry then copy mesh Anna Tian ANSYS Meshing & Geometry 0 July 30, 2012 16:59
[ICEM] Meshing adjacent wall geometry and simple ICEM questions everdimension ANSYS Meshing & Geometry 25 June 20, 2012 04:25
[ICEM] Best way to import geometry ICEM Cottbus ANSYS Meshing & Geometry 4 June 12, 2012 09:42
[ICEM] Ship Hull imported geometry nuovodna ANSYS Meshing & Geometry 0 February 25, 2010 10:09
