[ICEM] AutoCAD/AutoCAD inventor
Old   June 9, 2012, 00:33
Default AutoCAD/AutoCAD inventor
Tommy Lui
TommyLui is on a distinguished road
Hello everyone. I am started to learn new method to build up 3D model. The software I use is AutoCAD and AutoCAD inventor. I would like to ask how to import the geometry from AutoCAD / AutoCAD inventor into ICEM? Since I can only use .dwg format. ICEM warn me do not have .tin file. So what can I do to import my geometry into ICEM. Thank you very much.
TommyLui is offline   Reply With Quote
Old   June 9, 2012, 02:54
everdimension is on a distinguished road
File - Import Geometry
There you can choose all kinds of different formats, including DWG.
And if importing dwg doesn't work for some reason you can also export the model from Autocad into many other formats. It is not "only dwg" )) IGES might be your best choice.
everdimension is offline   Reply With Quote
Opening geometry from Inventor Cipherflak ANSYS 0 February 17, 2012 06:42
How to import Autodesk Inventor .ipt file into ANSYS FLUENT? soetommy FLUENT 0 September 27, 2011 00:35
[GAMBIT] Importing Coil from AutoCAD Inventor to Gambit kolapoasafa ANSYS Meshing & Geometry 3 July 14, 2011 07:26
[GAMBIT] Autodesk inventor to gambit problem arunammanath ANSYS Meshing & Geometry 3 February 23, 2011 05:24
AutoCAD Inventor vs. CFX (ICEMCFD) Mark Humphrey Main CFD Forum 3 January 16, 2007 19:37
