[GAMBIT] projecting a curve on a face in Gambit
Like Tree1Likes
  • 1 Post By -mAx-
Old   June 28, 2012, 19:51
Default projecting a curve on a face in Gambit
MAZI
mazdak is on a distinguished road
Hi.
I want create a circular area on a bend. I draw that circular area but when
i wanna to project that on the bend, for right half-part of that i deal with this error:
Projection of "edge. 27" on "face 1" can not create unique or correct edge.
i can not project edges 27 and 26 on "face 1" (face 1= red face).
edges 24 & 25 are easily projected, although they are similar to edges 27 and
26.
what should i do?
aim of this work is to create a circle with diameter of 25.4 mm on surface of a bend at teta=45 degree.
mazdak is offline   Reply With Quote
Old   June 29, 2012, 02:31
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Did you try to project edges 26 & 27 first (before edges 24 & 25)?
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   July 3, 2012, 18:10
MAZI
yes i have tried but no results
Old   July 4, 2012, 00:47
-mAx-'s Avatar
Maxime Perelli
ok
If your volume is still real you can try to split it with plane.
Create first plane (edge 24 & 25 belong to this plane)
Split desired surface with the created surface (plane).
If it is successfull, then reproduce it with the 2 other edges.
If not, you can provide me your dbs, I will take a look
Old   July 4, 2012, 14:55
MAZI
thank u for ur considering my inquiry. my email address is
mazdak_parsi2000@yahoo.com
plz send me your email address to send u the file.
thanks
Old   July 4, 2012, 17:37
MAZI
i tried to send you email in a couple of occasion but there is failure to sending.
Old   July 5, 2012, 02:46
-mAx-'s Avatar
Maxime Perelli
ok so I managed myself to split as you wanted.
Do following:
* project edges 26 & 27 on face1 with split option and with closest distance option
* project edges 24 & 25 on the other face with split option with closest distance option
Now your splits are done, but you have superposed surfaces.
Here is how I did: copy the rounded edge common to the 4 surfaces (the doted one on my picture) with vector (0 0 0)
Delete all the surfaces which should take place at pink or blue suface.
enable shaded mode on, and check if your geometry is hollowed (hollow at pink and blue surface)
Now you reconstruct both surfaces properly, by selecting edges (create face from wireframe and use the copied edge)
Again shaded mode on, and check if hollow is filled.
Do (to be sure):
*connect surfaces All
*connect edges All
*connect vertices All
Voila..
Then you only have surfaces and no volume.
So create the cap surfaces, and create the volume (stitch faces and select all surfaces)
for hexa meshing, sure without those 2 surfaces , it would be very easy to mesh your stuff. But if you need those surfaces, then you need to decompose your volume.
But first do your splits
Old   July 5, 2012, 03:44
MAZI
max
i don't know how to appreciate your time and help.
1) is it possible for you to send me your dbs files.
2) now, can i generate structured mesh?
Old   July 5, 2012, 04:06
-mAx-'s Avatar
Maxime Perelli
1-I cannot since you are working with an older version than mine
2-you can try to mesh your volume with hexa on the fly, but it will fail due those 2 surfaces
you need to decompose the geometry
Old   July 5, 2012, 04:09
MAZI
i have ansys 13
Old   July 5, 2012, 04:13
-mAx-'s Avatar
Maxime Perelli
i was talking about gambit: (i have 2.4.6)
I received a warning while opening your dbs file (>> older version)
Old   July 5, 2012, 04:20
MAZI
oh yes. max i really appreciate your help. i hope i could in touch with u and use ur knowledge.
Old   July 6, 2012, 02:29
-mAx-'s Avatar
Maxime Perelli
ok very quick generated, here is one method for full hexa decomposition.
I did it only on one half geometry:
Old   July 6, 2012, 14:44
MAZI
if i want to find y+ (in the wall-adjacent cell) in bend part what should i do?
cuz sounds that you can not define a curve in r-teta system.
Old   July 9, 2012, 01:45
-mAx-'s Avatar
Maxime Perelli
Then you have to add a boundary layer, but the split angle between yellow and green volumes will affect the cell-skewness at those jonctions
Old   July 9, 2012, 01:54
MAZI
no, imagine a regular bend without projection of that circular area.
when i do simulation of fluid flow in the bend i dont know how to find the amount of y+ in the bend part. cuz when i open the "plot" and select a wall of bend,
there is no r-teta coordinate. there are just X,Y,Z that i can put zero for two of them and put 1 for another one.
Old   July 9, 2012, 02:00
-mAx-'s Avatar
Maxime Perelli
if you select a wall, then you will have all info in that wall
But y+ is talking about distance from wall, so you have to pick info IN your domain
Old   July 9, 2012, 02:19
MAZI
so u mean that i can select the curve that is next to the wall and see how much is the y+ along that? if yes how?
imagine that i want to find the pressure distribution along the edge 30 which is located at outer wall of the bend. how can i find that?
Old   July 9, 2012, 02:27
-mAx-'s Avatar
Maxime Perelli
if you want to PLOT y+ along a curve, I am pretty sure you can create a rake-line in fluent-postprocessing (there are several tool in post-processing like slice etc...)
Once you have the point-line or surface you wanted, you can get all info you need
mazdak likes this.
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
imprint face in gambit Aleksander ANSYS Meshing & Geometry 2 June 5, 2009 01:14
Gambit face meshing with a common edge stella FLUENT 1 October 28, 2005 05:09
Points and face in gambit Lio FLUENT 6 July 6, 2004 02:54
