[DesignModeler] meshing
Like Tree1Likes
  • 1 Post By Gweher
Old   July 17, 2012, 13:33
Default meshing
tmeysam92
tmeysam92 is on a distinguished road
i want to mesh a cylinder, that has two parts.
interior part is fluid, and outer part is solid.
i used SLICES to create parts, then i can make hexahedral mesh.
now i want to import mesh to fluent, but when i import the mesh, there are a lot of walls and surfaces that it's really confusing.
i want two have just two part, but after slicing it convert to 8 part.
besids, i want to slice the geometry to mesh like the picture.
any suggestion??
tmeysam92 is offline   Reply With Quote
Old   July 17, 2012, 14:43
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
With this kind of segmentation, you will get cells with very low quality at the center of the pipe.
Use some kind of O-grid segmentation instead.
After splitting the geometry, you have to form an assembly from the single parts you created. This way, no walls will be created inside the mesh.
Make one assembly for the fluid, and a second one for the solid.
flotus1 is offline   Reply With Quote
Old   July 17, 2012, 14:49
tmeysam92
thank you for your reply.
do you know where is the assemble in ansys meshing or design modeler?
Old   July 18, 2012, 01:36
flotus1's Avatar
Alex
Sorry the exact word for the tool doesnt come to my mind right now.
I use the german version of ansys DM.
But it works like this: in Design Modeler, mark the parts you want to assemble and do a right-click.
In the context menu, you will find something like "form assembly" or whatever, it is pretty clear which one it is.
Old   July 18, 2012, 18:42
Gweher's Avatar
Gwenael H.
Gweher will become famous soon enough
Your problem has already been discussed in this post
As Alexander said, you need to form a new part (here one for your fluid domain and one for your solid)
Originally Posted by Gweher View Post
Just form a single part in DesignModeler. In the outline tree, select all your parts under Part section, then right click >Form New Part, this will fix your problem
I also agree with Alexander that your mesh slicing procedure will generate low quality elements at the center of the pipe, you should slice it to create an O-grid like this :
atheresia likes this.
Gweher is offline   Reply With Quote
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 05:22
Meshing locks workbench window. andy2o CFX 0 February 1, 2008 05:01
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 11:09
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 11:08
