July 19, 2012, 10:22 |
2D Sweep Method
Austin Murch
.I’ve been working on a 2D section of the wing airfoil and flap element. As you may know, CFX can’t handle 2D meshes, so the workaround given by ANSYS is to use a Sweep method to generate the one element thick mesh. I’ve found that meshing success is very unpredictable- one set of mesh settings will work fine, and then I make a seemingly innocuous change such as expanding the outer air boundary and the meshing will fail. Any advice on 2D problems or Sweep methods?
Thanks! |
airfoil, airfoil2d, cfx 14, sweep |
[ANSYS Meshing] Method: Sweep with Quads | peterputer | ANSYS Meshing & Geometry | 0 | July 18, 2012 13:22 |
[Gmsh] discretizer - gmshToFoam | Andyjoe | OpenFOAM Meshing & Mesh Conversion | 13 | March 14, 2012 04:35 |
Fluent 6.3.26 vs 12.1 and partition method | Anorky | FLUENT | 0 | April 27, 2010 10:55 |
Comparison: Finite Volume Method vs. Analytic Method | m-fry | Main CFD Forum | 1 | April 20, 2010 14:40 |
Code for most powerfull FDV Method | D.S.Nasan | Main CFD Forum | 6 | September 4, 2008 02:08 |
