[ICEM] Inflation in two direction
Old   July 31, 2012, 22:51
Default Inflation in two direction
HeatTransferFan is on a distinguished road
Hi everyone,
I am trying to model flow and heat transfer over a row of circular pins in ANSYS . I created the model and now I am trying to mesh it in ICEM. I have an enclosure with the pins in the middle, symmetry on the sides and no slip walls on the top and bottom. I also have an inlet and outlet section. I know there will be a boundary layer on the top and bottom and around each pin. The problem that I am having is that if I try to inflate the top and bottom, the prism layer around the pins disappears for some reason. Then if I remove inflation at the walls, the prism layer on the pins is there again. I am using a Tet patch conforming meshing for the fluid but I tried with MultiZone and I had the same problem. Obviously I am doing something wrong (and I believe something very stupid) but I can't figure out what. Also, does the order of the mesh control functions that you put matter? I mean, does it matter if I put body sizing before or after inflation?
Sorry but I'm in the process of learning CFD and I would really appreciate any help.
Thank you a lot for your help,
Krsto
HeatTransferFan is offline   Reply With Quote
Flow Direction: normal to boundary!!! Atit CFX 1 August 2, 2015 13:42
[ICEM] applying inflation in vertical direction MASOUD ANSYS Meshing & Geometry 5 February 4, 2011 11:53
[ICEM] Changing edge direction la7low ANSYS Meshing & Geometry 2 June 7, 2010 13:26
Large Valve Flow Analysis - Inflation Problem sercan85 ANSYS Meshing & Geometry 2 June 1, 2010 14:02
Inflation Gab CFX 6 August 24, 2005 22:45
