[ANSYS Meshing] Rotating machine
Old   August 2, 2012, 05:00
Default Rotating machine
Marco
msatrustegui is on a distinguished road
Hi everyone,
I'm trying to simulate a rotating machine and i am having some dificulties setting the named selections in the meshing.
Do i have to separate the body in two diferent parts (rotor and stator)? Do i have to declare as a wall the separation between the rotor and the stator?
Thank you.
msatrustegui is offline   Reply With Quote
Old   August 2, 2012, 07:57
Marco
My main problem is that I donīt know how to do all the named selection in the meshing. Do i have to name the bodies? Or only the surfaces? Fluent is giving me the following mistake:
********************* WARNING ******************************************
** Following mesh operations failed:
** Rename Zone [ 3 ] wall-exterior-part to wall-part_2-solid (Failed)
** Please ensure that your current Setup is valid.
Old   August 2, 2012, 12:07
Paulo
strobel is on a distinguished road
maybe you have same regions with 2 or more names.
strobel is offline   Reply With Quote
Old   August 3, 2012, 04:01
Marco
i've been working in a simplified model, using the following named selections:
-Fluid (aplied to all the bodies)
-Wall (All the stationary walls)
-Pressure-inlet (Inlet face)
-Pressure-outlet (Outlet face)
-Interface-inlet (face between rotor and stator in the inlet)
-Interface-outlet (face between rotor and stator in the outlet)
And Fluent show me the following mistake:
** Following expected zones were not found in the current mesh:
** part-solid
** wall-part-solid
** interior-part-solid
** Found Following new zones in the current mesh:
** interior-fluid
** wall-fluid
** fluid
What changes should i do in the named selections?
Old   August 3, 2012, 04:39
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
I think this mistake comes from the previously loaded mesh in fluent.
Are you using the workbench environment?
Anyway, before trying anything else, replace the mesh in fluent. (mesh - replace)
I am pretty sure that you need two cell zones for a rotor-stator setup. The faces belonging to the distinct cell zones have to be in different named selections.
Doesn't the fluent manual provide any guidance about the setup?
flotus1 is offline   Reply With Quote
Old   August 3, 2012, 06:03
Marco
Iīve tried changing the named selection in the mesh, and this time iīve put them like this:
fluid-estator (stationary-body)
fluid-rotor (rotating-body)
wall-estator (stationary wall faces)
wall-rotor (moving wall faces)
interface-rotor-inlet (common face between rotor and stator in the inlet)
interface-rotor-outlet (common face between rotor and stator in the outlet)
interface-estator-inlet (common face between rotor and stator in the inlet)
interface-estator-outlet (common face between rotor and stator in the outlet)
pressure-inlet
pressure-outlet
The warning i got in fluent was the following:
** Rename Zone wall to wall-exterior (Failed)
** part-solid
** wall-part-solid
** interface-outlet
** interface-inlet
** wall-exterior
** interior-fluid-estator
** interior-fluid-rotor
** wall-estator
** wall-rotor
** interface-rotor-outlet
** interface-rotor-inlet
** interface-estator-inlet
** interface-estator-outlet
** fluid-estator
** fluid-rotor
I've separate the body into two parts, consisting in the moving body(rotor) and the stationary body(estator).
I think the mistake must be on either the named selections, or the diferent parts of the body.
Thanks for the answers.
Old   August 3, 2012, 07:34
flotus1's Avatar
Alex
Were my annotations so inappropriate that you don' even want to comment on them?
Old   August 3, 2012, 07:51
Marco
So sorry, i got yesterday my new account and it's my first time in forums. So i`m not sure how i have to proceed. Next time i'll answer directly on your comments.
Old   August 3, 2012, 08:11
flotus1's Avatar
Alex
So? did you replace the mesh? Is it Workbench you are using?
Old   August 4, 2012, 14:06
Marco
I think the mistake must be in the way i create the named selections.
Old   August 4, 2012, 14:09
Marco
Yes, I'm using Workbench. I've divide the body in two parts, one consisting of the rotor and the other one of the stator. The diferent named selections i create are the following:
pressure-inlet
pressure-outlet
** part-solid
** wall-part-solid
** interface-outlet
** interface-inlet
** wall-exterior
** wall-estator
** wall-rotor
** fluid-estator
** fluid-rotor
Should i change the named selections?
Old   August 4, 2012, 15:06
flotus1's Avatar
Alex
All right, one last try. In the Fluent GUI, click on "mesh" -> "replace mesh" and select the mesh you just created.
Old   August 20, 2012, 06:58
Marco
Iīve also try that, but it's still getting me to the same problem. I donīt know how to define the named selections in the meshing part.
Old   August 20, 2012, 07:09
Marco
In this reply i've attached the file i'm working with. As i said before, my problem is that i donīt know how to define the named selections.
The model is divided in one part consisting of three bodies (all stationary) and one body (the rotating one).
The interior is fluid (air).
Thanks for the support.
Old   August 20, 2012, 10:08
flotus1's Avatar
Alex
Your zip-folder only contains the project-file, not the corresponding directory.
Old   August 21, 2012, 03:13
Marco
I canīt upload the rest of the files, they're too big.
Rotating Impeller Naith FloEFD, FloWorks & FloTHERM 22 November 5, 2012 08:53
Vertical Axis Wind Turbine Rotating Domain Problems TWaung CFX 4 May 1, 2012 03:14
BC in rotating machine Gerim55 FloEFD, FloWorks & FloTHERM 1 January 9, 2012 05:17
Distributed Parallel on dual core remote machine Justin CFX 1 February 3, 2008 17:23
Rotating machine analysis Hans Main CFD Forum 1 November 19, 2002 06:49
