[ICEM] Automatic linear interpolation of parameters when splitting blocks
Old   August 14, 2012, 07:30
Default Automatic linear interpolation of parameters when splitting blocks
Ivan
Ivan is on a distinguished road
After I create the blocking for my domain and link all the edges with the curves, I split the block (imagine as it was a pipe with a single block) in many blocks (for parallel purposes then). The pipe inlet and outlet are circular, but when I split the block, the new (many) blocks I have created have their edges not associated with any curve, so they are "squares" istead of being circles (affecting the mesh). Actually my domain is a trapezoid, and I have the parameters at the inlet different from those at the outlet. I would like also that those parameters are automatically linearly interpolated on the edges between inlet and outlet (see example below).
Up to now, the way I'm following is the (very boring) one of 1) creating many curves inside the domain, so to associate the "squared" edges to the circular curves one by one; and 2) set manually a linear interpolation edge by edge for both the spacing and the ratio.
Is there a way to quickly by-pass this long procedure and automatically obtain, on one side, "circular edges" and linear interpolated values?
EXAMPLE. I have a circular inlet of radius 1, spacing s1 and ratio r1, a circular outlet of radius 2 with spacing s2 and ratio r2. If I split the block in two blocks at exactly half domain, I would like that the new four edges are automatically set with a spacing and a ratio half way between those at inlet and outlet, and automatically associated to a circle of radius 1.5.
Is that possible? Does anyone have an idea?
Thank you
Ivan
Ivan is offline   Reply With Quote
[Commercial meshers] converting Fluent mesh to openfoam standard mesh deepesh OpenFOAM Meshing & Mesh Conversion 31 March 29, 2017 05:59
dsmcInitialise - dsmcFoam archymedes OpenFOAM Pre-Processing 94 July 15, 2016 16:14
[ICEM] Splitting the blocks saisanthoshm88 ANSYS Meshing & Geometry 5 March 25, 2016 11:31
Beginner: Splitting blocks dewittcr Main CFD Forum 0 June 24, 2011 10:55
solution diverges when linear upwind interpolation scheme is used subash OpenFOAM 0 May 29, 2010 01:23
