[ICEM] Define node distribution on an edge based on an equation in ICEM |
August 13, 2012, 15:48 |
Mustafa
Rep Power: 14 |
Is there a way in which you could define node distribution on an edge (in ICEM) using your own function? For example: I want my nodes on an edge to follow the distribution y=0.0557x+0.2 where y= delta yplus and x= yplus I am aware that I could use Linear graph option but I don't know: a) how to interpret Relative point density b) and how to define your graph based on an equation. Thanks in advance. |
September 3, 2012, 07:02 |
Mustafa
Rep Power: 14 |
Is there a way you could define node distribution on an edge in ICEM using your own equation? Thanks, sidd |
How to define multiple fluid regions in icem | user0314 | ANSYS Meshing & Geometry | 6 | June 2, 2020 00:28 |
Installing OF 1.6 on Mac OS X | gschaider | OpenFOAM Installation | 129 | June 19, 2010 09:23 |
Diff b/w node based & cell based methd | Murthy | FLUENT | 0 | April 2, 2008 13:18 |
is there any method give node based velocity BC? | daniel | FLUENT | 2 | July 18, 2006 21:21 |
node based or cell centered Ts values | acboge | FLUENT | 0 | February 6, 2004 06:41 |
