[ICEM] How can I extrude a 2D Hexa Mesh along a center curve?
Like Tree1Likes
Old   November 8, 2012, 06:55
Default How can I extrude a 2D Hexa Mesh along a center curve?
Daniel Ceglarski
Daniel C is on a distinguished road
Hallo everybody!
My concern as follows:
I have created a simple 2D Hexa Mesh in ICEM. Now I want to extrude this mesh along a guiding curve, which is normal to the surface of the mesh. In that manner, I try to mesh a serpentine cooler with a lot of bending. Creating a blocking topology is much more time consuming, I think.
What I've tried:
I made a 3D Blocking from 2D (10mm in Y-Direction). Then I used Extrude Face(s) -> Extrude Along Curve along curve, but I can't select all the curves for extrusion. So, how can I extrude along the whole curve?
Does anybody has a hint for me?
Thank you very much!
Daniel
http://imageshack.us/photo/my-images/585/icem.png/
Daniel C is offline   Reply With Quote
Old   November 8, 2012, 13:01
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
Somebody answered you but in a different thread...
Broly said:
you could try this :
geometry -> create/modify curve -> concatenate/reapproximate curves
You will end with one curve, and it should work.
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   November 8, 2012, 23:45
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Can we extrude the 2d mesh in pre-mesh? or it only works when pre-mesh is converted into unstructured mesh?
Far is offline   Reply With Quote
Old   November 8, 2012, 23:47
diamondx's Avatar
Ghazlani M. Ali
You can extrude 2d mesh n the premesh
Regards,
Ali
Old   November 9, 2012, 03:17
AB
BrolY will become famous soon enough
In fact, you extrude the block, so at the end, it's like extruding the pre-mesh.
BrolY is offline   Reply With Quote
Old   November 9, 2012, 03:20
Far
Sijal
extrude block only work on the 3d blocks
anand32 likes this.
Old   November 9, 2012, 03:57
Daniel Ceglarski
Okay, I have concatenated the curves, now I can select the whole curve as a tracking curve. But I don't get a satisfying result (See picture 1).
In a second attempt I changed the geometrie. Now I have one outer and one inner curve as a track for the extrusion. I still get no result (See picture 2).
I tried both, pre-mesh and unstructured mesh.
Old   November 9, 2012, 04:01
Far
Sijal
see this http://www.cfd-online.com/Forums/ans...ing-edges.html
Old   November 9, 2012, 04:03
AB
You should extrude the block curve by curve., and be sure that you have a split at each geometry change. I've done it plenty of times, it works well.
Old   November 9, 2012, 05:42
Daniel Ceglarski
Thank you Far, that helped a lot.
ICEM seems to have some difficulties with narrow radius in curvature (Picture 1 and 2). So the centerline of the rectangle duct is truly the better tracking curve (Picture 3). Now I have to adjust the number of layer properly to have the best fit to my curvature.
Another problem is, that only the node distribution from the face is copied each time. That is clear to me, because each block has a different size compared to the original block. So ICEM does not know whether the number of nodes or the spacing is impotant. What is the best practice to handle this problem? Do I have to go to the Curve Mesh Setup?
Thanks again!
Daniel
Old   November 9, 2012, 05:59
Far
Sijal
I usually define the premesh parameters manually. Did you check the premesh? Is it OK?
I see you have made the few splits at the curvature, this should work!
Not the curve mesh set-up, use the edge mesh parameters. You can also define the default no of nodes so that you will have reasonable no of nodes on each segment of edge while you are extruding blocks.
Old   November 9, 2012, 06:40
Daniel Ceglarski
I did not make any splits at the curvature. The extrusion went automatically.
The pre-mesh was fine. My first block contains 28 nodes in x-, 11 nodes in y- and 21 in z-direction. I extrude in y-direction.
The number of nodes is alway set to 2 nodes in depth as I extrude. How can I set the default number of nodes. I hooked the Nodes Locked option in the Edge Params, but that did not work.
How can I define the default no of nodes? Sorry form my stupid questions, but I am a complete newbie in ICEM :-)
Old   November 9, 2012, 07:01
Far
Sijal
go to premesh parameters. update all in first tab (update sizes)
Check premesh, if mesh looks decent (like 4-8 nodes on edge) then ok, otherwise go to 2nd tab (scale sizes) and try with 2 and contiue clicking apply untill you are satisfied with meshing.
I request Simon to provide the defaults for the no of nodes on edge, so that user can set it in the starting of project like we do in gambit and gridgen/pointwise
Old   November 9, 2012, 07:32
Daniel Ceglarski
That is a suitable method for me. Thank you!
Could you still give me a hint, how to fit the blocks to the curvature? The blocks do not want to fit it! They dont't adopt the edge association I made in the Associate Edge to Curve tab. Do I have to set the association manual edge for edge? That would be horrible!
Old   November 9, 2012, 07:36
Far
Sijal
did u try the auto association? This is the last option in association panel
Old   November 9, 2012, 07:43
Daniel Ceglarski
It's a pity, auto association does not work. See picture.
Old   November 9, 2012, 07:50
Far
Sijal
manual method
Old   November 9, 2012, 08:00
Daniel Ceglarski
Haha ! Okay, this is my first try and this is only a small sample duct.
If I have , let me say, 100 and more bendings in a more complex duct, I am quite busy for the next time .
Summary;
1. I associated the two top edges to the top outer and inner curves of the duct.
2. I extruded the blocking with 53 layers along the center curve of the duct.
Where I went wrong?
Old   November 9, 2012, 08:09
Far
Sijal
nothing wrong. try manual association and then check pre mesh
Check 89 slide https://docs.google.com/file/d/0ByIL...MjQ/edit?pli=1
Old   November 9, 2012, 08:35
Daniel Ceglarski
Good script! I will use it in the future. What did you mean with >>Check 89 slide<< ?
[ICEM] Extrude Mesh without internal faces TWaung ANSYS Meshing & Geometry 3 May 29, 2019 05:18
ICEM CFD 5.0 - 2D to 3D Mesh Extrude James Date CFX 7 October 22, 2013 03:46
[ANSYS Meshing] Finned tube Hexa mesh aliemadi ANSYS Meshing & Geometry 5 May 14, 2012 19:58
[ICEM] issue occur after extrude 2D airfoil mesh and convergence problem in CFX shiyun ANSYS Meshing & Geometry 4 May 9, 2012 19:55
[ICEM] Hexa Mesh Smoothing Jules ANSYS Meshing & Geometry 6 December 4, 2010 18:00
