December 6, 2012, 11:29 |
Design Modeler: Split faces
Rep Power: 13 |
Hi everybody,
I am trying to make a simple 2D model and I need 3 independent bodies next to each other. i make 3 different sketches but when I create a "Surface from Sketch" they combine to produce a single body. I need the bodies to be independent!. I tried with "Split Faces" but somehow it doesn't work. Thanks for your help |
December 7, 2012, 05:49 |
Rep Power: 13 |
December 10, 2012, 04:19 |
Rep Power: 13 |
No solutions?
December 10, 2012, 04:30 |
Do you actually have three different sketches in the model tree or have you just sketched three shapes in the same sketch?
A screenshot of the situation? |
December 10, 2012, 04:44 |
Alex
Rep Power: 47 |
Always the same question...
After creating the "surface from sketches", you have to freeze the created bodies (extras -> freeze). Now there should be 3 different bodies in the project tree. Select them all, right click and select "form new part" Now you are ready to go. |
December 10, 2012, 05:28 |
My interpretation is that the bodies are supposed to be independent next to each other, ie not touching. But if they are touching, then yes that is the answer.
December 10, 2012, 07:29 |
Rep Power: 13 |
Yes they are touching and yes that was what i needed. Thank you very much!
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
[Other] Mesh Importing Problem | cuteapathy | ANSYS Meshing & Geometry | 2 | June 24, 2017 05:29 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
