[ANSYS Meshing] Error in setup after meshing (fluid & solid)
Old   December 8, 2012, 12:34
Default Error in setup after meshing (fluid & solid)
zlaugh is on a distinguished road
I'm doing natural convection to study heat transfer coefficient. therefore has 2 body, one solid geometry and one fluid control volume.
i created the solid geometry in 1 body first then create the control volume with 'add frozen' and specify it to fluid.
picture below is pre mesh.
then i just click update and mesh it without changing anything. post mesh picture as shown below
is this the correct way of meshing? or should i change some of the setting?
in workbench, geometry and mesh has tick beside it so i assume it is ok. but when i open setup, it shows 'model information is incompatible with incoming mesh' like picture below
and this is how it looks after i click ok.
can someone pls tell me what's wrong?
and how do i set boundary condition? treat every surface as wall?
all surface has set temperature as 303K and the solid geometry as higher temperature?
zlaugh is offline   Reply With Quote
goddamnit: how to set up heat transfer from fluid to solid macfly FLUENT 7 June 16, 2012 11:50
heat conducting solid within a fluid medium? sieginc. STAR-CCM+ 1 February 19, 2012 11:48
Re-meshing a deformable solid body in a fluid brashear CFX 6 December 12, 2011 11:13
fluid structure interaction taru agrawal FLUENT 4 September 10, 2007 03:12
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
