[ICEM] regarding blocking and splitting
Old   December 17, 2012, 15:42
Default regarding blocking and splitting
Rajukiran Antham
RAJ KIRAN is on a distinguished road
hello everyone
i'm new to icemcfd ,plz help me out how to use index control while splitting the blocks..
looking forward for a reply
RAJ KIRAN is offline   Reply With Quote
Old   December 17, 2012, 15:49
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
when i just started using index blocking , i just used the select corner option, fast and easy...
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   December 17, 2012, 17:43
François Grégoire
macfly is on a distinguished road
Here is an exercise for you to understand the possibilities of index control:
- Open the attached zipped project.
- Play with the display of the parts to see what's what.
- Let's say you want to associate all the edges in the cube.
- To associate the edges to curves contained in the parts CURVES1 to CURVES4, play with the K dimension of the blocking index control. Example: display BLOCKING and CURVES1 and set the index control as shown in the attached picture.
- To associate the curves contained in the parts CURVES5 to CURVES8, play with the I dimension of the blocking index control.
- You will realize that you can do the edge associations by working in 2D planes sequentially, instead of having your eyes crossed trying to decode a puzzle of 3D edges.
macfly is offline   Reply With Quote
Old   December 18, 2012, 00:15
Rajukiran Antham
thanks a lot
[ICEM] Blocking topology for cruciform fins siw ANSYS Meshing & Geometry 22 September 6, 2012 04:55
[ICEM] Automatic linear interpolation of parameters when splitting blocks Ivan ANSYS Meshing & Geometry 0 August 14, 2012 07:30
[ICEM] Dealing with Singularity..! JOKER ANSYS Meshing & Geometry 15 November 10, 2010 07:57
how to split hex mesh in icem with desired height? adam2008 ANSYS Meshing & Geometry 3 August 27, 2009 14:59
HELP: ICEM blocking and vorfn / orfn guest7777 CFX 4 November 2, 2007 11:28
