[DesignModeler] how to subtract a surface body from a solid body?
Old   December 28, 2012, 18:14
Default how to subtract a surface body from a solid body?
yahya
yahya is on a distinguished road
How to subtract a surface body that lies inside a solid body from the whole solid body..when I try to do this I get the following error: "Error: Operation would result in non-manifold bodies."
Any suggestions?
yahya is offline   Reply With Quote
Old   December 30, 2012, 07:04
yahya
any help guys?
Old   January 7, 2013, 04:22
Josef Runsten
jrunsten will become famous soon enough
Send a message via MSN to jrunsten
Well, a surface body has no volume, so you aren't really subtracting anything. More information might help us help you
jrunsten is offline   Reply With Quote
Old   January 7, 2013, 09:35
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
with easy geometries you can try surface from edge or face (i don't remember if face exists...) and then i sew these surfaces together. i have never tried that on round geometries like a sphere tough...
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   January 7, 2013, 11:00
diamondx's Avatar
Ghazlani M. Ali
here something you can also do, it worked for me once, export your geometry in STEP file.
open it in ICEM CFD, export it again, then import it in designmodeler...
Regards,
Ali
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[DesignModeler] Merge Surface Body and Solid Body prikeyma ANSYS Meshing & Geometry 5 April 16, 2015 07:01
[DesignModeler] Generating solid body between two bodies. yshi095 ANSYS Meshing & Geometry 8 October 1, 2013 06:07
Particle attachment to solid surface wall Ashraf STAR-CCM+ 1 August 4, 2012 07:36
solid edge problem....can you help? cindy Main CFD Forum 3 April 5, 2004 13:43
