[Other] Problem in C meshing of aerofoil
Old   January 4, 2013, 05:52
Default Problem in C meshing of aerofoil
ashish
Ashish22 is on a distinguished road
hi,
i am referring tutorial for aerofoil meshing given at
"http://www.eng.ox.ac.uk/thermofluids/people/david-gillespie/fluids-course-work-module/wing-modelling-materials/Workbench_Tutoal_Airfoil_Adapted_for_Oxford.pdf/at_download/file"
i followed each and every step from tutorial, but mesh generated by me is not same as in PDF
i'm attaching expected and generated mesh
please give me solution
mesh genrated.pngri
Ashish22 is offline   Reply With Quote
Old   January 4, 2013, 10:37
Rajukiran Antham
RAJ KIRAN is on a distinguished road
may be you have associated edges to curves in wrong manner..try this famous tutorial once
http://www.youtube.com/watch?v=tYrbScUH9RE
RAJ KIRAN is offline   Reply With Quote
Old   January 6, 2013, 01:47
ashish
Thank you for your reply
but i'm working in workbench not icem, if you find anything in workbench please reply
Old   January 6, 2013, 05:10
Umut Can
Umuteng is on a distinguished road
I think you should curve the trailing edge. And be sure that axis is exactly at the trailing edge of airfoil. Also try to divide domain different sizes.
And what is the airfoil?
Umuteng is offline   Reply With Quote
Old   January 9, 2013, 01:24
Default Regarding your problem
Ashutosh
mesh_generation is on a distinguished road
Dear Ashish
Try to unselect surface under geometry tab in modal tree. then try to view it again or if it is 2D geometry try curver mesh setup first then go for surface meshing.
mesh_generation is offline   Reply With Quote
Old   March 7, 2013, 11:26
Kurt Cuschieri
kurt2591 is on a distinguished road
Ashish, I have the exact same problem! I'm working on a Selig S3024 aerofoil and the top quarter of the circular mesh (for the top surface) has a nice hexagonal mesh but the bottom quarter of the circular mesh (for the bottom surface) is tetrahedral and is giving me cells having very high skewness.
Have you managed to figure out how to get a good mesh for both circular quarters?
kurt2591 is offline   Reply With Quote
Problem with querying the meshing database in CFX-Pre ashtonJ CFX 18 April 18, 2023 23:49
[ICEM] 2d Aerofoil meshing in ansys ICEM syler3321 ANSYS Meshing & Geometry 2 February 3, 2012 01:59
Strange ANSYS Meshing 13.0 Problem brunob ANSYS Meshing & Geometry 3 June 21, 2011 20:03
[ICEM] ICEM meshing problem xyq102296 ANSYS Meshing & Geometry 6 October 28, 2010 10:09
Meshing an aerofoil with a plain flap Fatou FLUENT 0 November 15, 2005 14:24
