[ANSYS Meshing] External aerodynamics of car (geometry and mesh mothod)
Old   January 7, 2013, 23:09
Default External aerodynamics of car (geometry and mesh mothod)
Jakub Radziwon
qbus_r is on a distinguished road
Hi everyone.
I have question about external aerodynamics of car, in specific question about preparation of the model.
I have prepared my model in SolidWorks and then exported into Design modeler. Now I got problem with wheels. If I want to have my car accurate on road I have to cut out tires tangent to the road, but no modeler ( i think) will allow such an operation because it will fire the "zero width geometry" error. So I thought of lifting my car up for example for one millimeter. But how can I connect later in mesher surfaces of my wheels and road as I don't want to have slim gap there ?
My other question is about meshing methods. I heard from Ansys re-seller and my tutor in university that for CFD simulations I should use new CutCell method, but i can't find any information about this method ( besides ansys' ads ). On the other hand everyone says that for aerodynamic simulation tetra should be used. Which one is better and why ? I couldn't find any comparison of those methods.
qbus_r is offline   Reply With Quote
Old   January 8, 2013, 01:41
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
cutcell is good method. But I guess with tetra + prism + Hexcore (upto wall) will do the job.
But two points are important to consider before proceeding to the volume mesh (in ICEM or Tgrid):
1. Geometry should be of high quality and water tight
2. Very good quality surface mesh.
Another option in ICEM would to use the octree (hence no step 2). Delete volume mesh and smooth surface. For volume meshing use denauly with AF and Tglib in ICEM or use Tgrid.
Far is offline   Reply With Quote
Old   January 8, 2013, 10:00
Jakub Radziwon
Thanks for quick response.
I am kind of stuck with Ansys + Fluent system. I think my geometry is tight as it is not created from surfaces -> I exported solids from Solidworks.
About mesh quality- I know that i should consider mesh with skewness < 0,98 ( 0,95). For now I have bigger skewness, how can I show those skewed cells (I know itis possible, but i couldn't manage to) ? Without that I can only predict where the mesh is highly skewed.
And about my second question, the wheels, how should I connect them to the road?
Old   January 8, 2013, 21:36
Crank-Shaft's Avatar
Ovi
Crank-Shaft is on a distinguished road
The contact patch with the road may be modeled in different ways depending on the simulation intent. Are you trying to simulation a moving ground or a static vehicle? This will dictate what type of boundary condition you specify.
Mechanical Engineering
Sydney, Australia
Crank-Shaft is offline   Reply With Quote
Old   January 8, 2013, 22:30
Jakub Radziwon
I want to do both simulation. For now i modeled something more like "wheel chocks" (as solid)and now I am trying to obtain mesh.
aerodynamics, ansys, cutcell, mesher, method
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
