[ICEM] meshing
Old   January 9, 2013, 11:02
Default meshing
tmeysam92
tmeysam92 is on a distinguished road
I want to mesh the valve (Fig.1) in ICEM.
If you look at the geometry (Fig. 2), you see that there is a hole in it, but when i use blocking startegy , I do not know how to produce the hole in blocking. what should i do?
thanks in advance.
tmeysam92 is offline   Reply With Quote
Old   January 9, 2013, 11:07
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
make splits until you get a block that has same topology as the hole. then delete it...
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing David-CFD ANSYS Meshing & Geometry 1 April 1, 2011 05:22
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 11:03
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 11:09
Volume Meshing & Face Meshing? singularity of grid ken FLUENT 0 September 4, 2003 11:08
