[ICEM] How to deal with self-intersecting surfaces?? |
February 18, 2013, 13:44 |
Hi everyone,
Here's my issue. I have a geometry I'm trying to surface mesh in order to use for CFD. Basically it's a group of coils that are to be placed in a fluid domain in order to obstruct the flow. However, inherent to the finite element simulations that I used to generate the coil configuration, the coil geometry is self-intersecting (i.e. the coil tubes overlap at some points). You can imagine this creates problems when volume meshing. Is there ANY way in ICEM to deal with these overlaps (get rid of the interior surfaces altogether)? I attached some images to show you what I'm talking about. The second image was taken from the ICEM help files to show you how the tubes look when they are overlapped. Thanks for the help! |
February 19, 2013, 09:31 |
Stuart Buckingham
Rep Power: 25 |
Try using the top down (Octree) mesher with a material point defined at some point in the fluid volume. I think this will walk over the dirty geometry. Once you have your mesh, throw away the volumes to be left with the surface mesh only.
Stu |
August 19, 2015, 12:24 |
Mohamed Ibrahim
I am getting the same problem .. When I run Fault Detection in DesignModeler, I found self intersections .. Can anybody help ?
intersect, non-manifold, surface mesh |
how to get forces on Iso-Clip Surfaces and How to get forces in cylindrical coordinat | CFD XUE | FLUENT | 3 | March 18, 2015 03:28 |
[snappyHexMesh] snappyHexMesh not refining surfaces | Hydro1004 | OpenFOAM Meshing & Mesh Conversion | 3 | August 29, 2012 11:56 |
Modeling both radiation and convection on surfaces - Ansys Transient Thermal R13 | s.mishra | ANSYS | 0 | March 31, 2012 04:12 |
[ICEM] Surfaces intersecting after removing o-grid block | rich85 | ANSYS Meshing & Geometry | 3 | April 26, 2011 10:05 |
[snappyHexMesh] problemes modelling surfaces with snappyhexmesh | gija79 | OpenFOAM Meshing & Mesh Conversion | 5 | June 30, 2010 13:50 |
