[GAMBIT] Gambit Blade cascade
Old   February 18, 2013, 16:10
Default Gambit Blade cascade
dragonrobbo is on a distinguished road
Hi
Does anyone know how to create a blade cascade in gambit, then meshit? Its for my final year project and im running out of time. This forum is my last hope.
Please help!
Thanks
dragonrobbo is offline   Reply With Quote
Old   February 20, 2013, 08:21
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
create a blade, and then use copy tool
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   February 20, 2013, 17:13
Thanks,
I have manged to do that but every time I try to mesh it I get an error "problem with permament face overloop"
Any ideas as Im not very good with gambit!
Cheers
Old   February 21, 2013, 01:06
-mAx-'s Avatar
Maxime Perelli
can you post pictures of what you did
Old   February 22, 2013, 16:11
Hi this is what I did!
Thanks again
Old   February 22, 2013, 16:13
Attachment 19316
Attachment 19317
Attachment 19318
Attachment 19319
Old   February 25, 2013, 02:08
-mAx-'s Avatar
Maxime Perelli
Your surface seems to be ok.
I would merge all your edges from airfoils.
If you will work with periodicity, remember that your periodic edges have to be linked (with mesh)
Old   February 27, 2013, 23:02
CFD User
aditipatel7 is on a distinguished road
Hey max,
What do u mean by "If you will work with periodicity, remember that your periodic edges have to be linked (with mesh)?"
Isn't it obvious that they will be linked with a mesh. How else can a simulation be done. M confused.
Can you explain your statement in detail?
aditipatel7 is offline   Reply With Quote
Old   February 28, 2013, 06:41
-mAx-'s Avatar
Maxime Perelli
http://aerojet.engr.ucdavis.edu/gamb...e/mg04.htm#777
Check the Note
blade cascade compressor Bentra FLUENT 0 June 19, 2012 10:33
Computational domain for a blade cascade aledexe CFX 2 June 3, 2012 06:43
[Commercial meshers] Handling cyclic BC from gambit to openfoam for a cascade airfoil problem - OF 1.6 maverick OpenFOAM Meshing & Mesh Conversion 2 June 18, 2011 04:36
2D Compressor cascade study using DFLVR blade kiran FLUENT 1 May 24, 2007 15:01
Creatingfan blade profile in GAMBIT Jenny FLUENT 5 April 28, 2005 05:52
