[ICEM] mesh not showing
Old   March 20, 2016, 05:09
Angry mesh not showing
kasra
kazra is on a distinguished road
hello
im trying to mesh a geometry using Mutizone method. so when I try to generate the 2D surface mesh using ICEM CFD and I check the premesh option after the recomputing finishes still it does not show the mesh. now I don't know whats going on here as im new to ICEM and would appreciate any help.
thanks in advance
kazra is offline   Reply With Quote
Old   March 20, 2016, 08:45
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
did you try multizone tutorial on ansys portal?
Far is offline   Reply With Quote
Old   October 19, 2017, 01:02
Andrew Fung
andrewfzy is on a distinguished road
I am facing the same problem as well. I have followed the instructions in the multizone tutorial. Build diagnostic topology (all curves in red) > set global mesh size > part mesh setup > auto surface blocking. But the pre-mesh would not appear.
I have succeeded on a simpler geometry before so perhaps it is due to the complexity of my geometry. It is the fluid region around a propeller blade and its shaft.
Any help would be appreciated, thanks!
andrewfzy is offline   Reply With Quote
Old   May 20, 2019, 05:11
MaximusXIV is on a distinguished road
Hello ICEM people,
same here.
I recomputed the premesh like I did already about 1,000 times in my ICEM project (and it worked the 1,000 times, I could see my premesh). The only difference now is that my total number of elements is much higher (Right-Click on Pre-Mesh (green arrow is there, but premesh is not showing), Pre-mesh info ->about 50,000,000 Quads, in 2D). So maybe it depends upon the amount of data generated.
Maybe a software problem (ICEM CFD 19.2)?
Thank you in advance!
MaximusXIV is offline   Reply With Quote
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 07:34
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
