[ANSYS Meshing] Error: Patch-conforming tetrahedron mesh failed possibly because of bad boundary mesh
Like Tree4Likes
  • 4 Post By jwillie2000
Old   March 4, 2013, 04:02
Default Error: Patch-conforming tetrahedron mesh failed possibly because of bad boundary mesh
James Willie
jwillie2000 is on a distinguished road
Hi Everyone,
I am trying to get a mesh with two lobes in one of the fluid regions that would be rotating. So i used the sweep method for this region and use automatic for the other two regions. When i generate the mesh i am getting the error message in the title above and i am not sure why. I know the mesh should be non-conformal at the interface between the rotating and static regions. Could this be the reason for the error? and if yes, how can i make the mesh at the interfaces non-conformal?
Thanks!
Jimmy
jwillie2000 is offline   Reply With Quote
Old   March 5, 2013, 06:35
James Willie
The mesh is now okay. The problem was in the lobes fluid region. I had to first increase the defeaturing tolerance and then i had to reduce the global mesh size to 1 mm. The smallest gap between the two lobes is 1.2 mm. This solved it.
Jimmy
[ICEM] Hybrid mesh for 2D boundary layer Bigio ANSYS Meshing & Geometry 33 November 18, 2019 09:15
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
[OpenFOAM] ParaView/Parafoam error when making animation Disco_Caine ParaView 6 September 28, 2010 09:54
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
New topic on same subject - Flow around race car Tudor Miron CFX 15 April 2, 2004 06:18
