[DesignModeler] Big problem with named selections
Like Tree1Likes
  • 1 Post By flotus1
Old   March 13, 2013, 06:07
Default Big problem with named selections
lacaillg is on a distinguished road
I'll try to explain my problem simply : I have to simulate a water flow in a vertical tube in the ocean. I have chosen an asymmetric method and just model half of the tube and the ocean on ANSYS WORKBENCH. The problem is : my tube is supposed to have 0 thickness, so I decided to put two blocks : one with the fluid which is in the tube and the other one on the right with the water in the ocean. The problem is I want to name the Edge which is between those two parts but I can't ! When all the parts of my system are shown on the screen I just can't select this Edge (the two blocks become stick together) and when I choose to hide one block, name the selection and Generate, my model is said to be unvalid or something like this ... It's necessary for me to have this "wall" named selection to apply conditions on the wall (non slip etc ...).
I've got the same problem with the inlet and outlet of the pipe, because I'm also modeling the ocean under and above ... Please help !
Thanks
Guillaume from France
lacaillg is offline   Reply With Quote
Old   March 13, 2013, 06:19
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
The two blocks you are talking about... I guess they are created with the "surface from sketches" method with one sketch for the fluid inside the tube and another sketch for the surrounding fluid..
Did you select "add frozen" in the options of the surface creation?
This should enable you to select the faces individually.
PSYMN likes this.
flotus1 is offline   Reply With Quote
Old   March 13, 2013, 06:38
That's it ! Thanks a lot flotus1 !
design modeler, inlet and outlet, named selections, thickness, wall
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 11:39
A big problem about scour around pile bojiezhang FLOW-3D 27 July 3, 2012 16:53
activating field Averages m.maneshi OpenFOAM Running, Solving & CFD 18 September 8, 2010 13:29
Solver problem with a big amount of reactions Leonid CFX 2 April 9, 2007 10:38
I have a big problem of convergence, please help ! amel FLUENT 3 February 15, 2007 15:32
