[DesignModeler] DM- how to create Solid and Fluid _2D
Old   March 18, 2013, 07:20
Default DM- how to create Solid and Fluid _2D
Moha
ahvz is on a distinguished road
Hi, How to create two different layer (2D) one is solid and another attached to this layer is Air (fluid). I have see only one body created for all geometry with its solid while is not the case that I expected
any help is welcome to my problem...
regards
ahvz is offline   Reply With Quote
Old   March 18, 2013, 09:43
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
in 2d, geometries are basically surfaces. use split faces. and rename them Fluid and sOLID.
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   March 18, 2013, 10:38
Moha
Thank you Ali,
Now I have two bodies. how to connect this two together ? from one edge ? I tried "connect" option but there are not possible, let me know any ideas please...
[Commercial meshers] Create solid mesh around fluid mesh wcpvandervelden OpenFOAM Meshing & Mesh Conversion 0 June 21, 2012 10:05
Actuator disk model audrich FLUENT 0 September 21, 2009 07:06
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 01:07
How to create multiple solid fluid domain? Mishar FLUENT 0 January 25, 2005 03:05
