[ICEM] Multizone meshing Problem for External Flow Meshing |
March 19, 2013, 10:24 |
Ali
i am trying to mesh on a fin-body configuration using multizone option in ICEM 14.5, facing problem while filling the 2D block to 3D fill. The geometry consists of body+fins (360 deg no symmetry) and a farfield (cylinder). The body is enclosed in the farfield surface (no contact between the body and farfield). The material point is defined between the body and farfield. 2D surface block initialized very well. When I tried to fill it with Multizone with advanced filling option, volume filled the farfield ignoring the body. No volume mesh, why? Anybody can help me? Its an external flow problem.
Best Regards Ali Last edited by Hybrid; March 19, 2013 at 10:27. Reason: To edit title, subject heading |
March 20, 2013, 09:51 |
Simon Pereira
Rep Power: 47 |
at the moment, 2D to 3D fill only works if the faces are all connected. It will not support this situation where there is no contact between the FF and the body.
You could try creating a symmetry model (the symmetry plane could connect the FF and Body) and then mirror it if you need a full model.
----------------------------------------- Please help guide development at ANSYS by filling in these surveys Public ANSYS ICEM CFD Users Survey This second one is more general (Gambit, TGrid and ANSYS Meshing users welcome)... CFD Online Users Survey |
March 24, 2013, 13:10 |
Ali
It works really great with a half mesh.
The problem arises at the sharp trailing edge of the airfoils, a very low quality mesh Quality is around 0. in that areas. How can I handle that while working in multizone meshing?
Best Regards Ali |
March 25, 2013, 09:26 |
Simon Pereira
Rep Power: 47 |
Maybe a picture of the problem would help.
March 28, 2013, 12:30 |
Ali
here are a pic and project file attached.
Best Regards Ali |
March 28, 2013, 14:07 |
Simon Pereira
Rep Power: 47 |
In your case, you had very high aspect ratio quads... I didn't even see a volume mesh, but if you had generated one, the pyramids against those quads would have been even worse...
How about a nice MultiZone swept mesh instead? Something like this (the CYAN mesh is a cutplane thru a swept quad dominant MZ mesh). MZ_Wing.jpg I attached a blocking file. Let me know if I have permission to post a tutorial on this model and I will make a 1 minute demo to show you how it is done. Best regards, Simon
March 28, 2013, 14:08 |
Simon Pereira
Rep Power: 47 |
I should note that for the best quality mesh, I would recommend a hexa blocking... But the MultiZone Mesh can be done without any blocking skills...
March 28, 2013, 16:36 |
Ali
Error in opening Blocking File. Better to add geometry as well.
You can post the tutorial privately if not possible to post here.
Best Regards Ali |
March 28, 2013, 16:42 |
#9 | |
Ali
Prisms not there, what happened with quality when prism layers will present?
can this technique be used for complex configurations like whole aircraft with control surfaces etc ? Quote:
Best Regards Ali |
March 29, 2013, 09:24 |
#10 | ||
Rep Power: 20 |
Boundary condition problem for open channel flow | Andy | CFX | 9 | June 11, 2016 07:20 |
[ANSYS Meshing] Solid inside Fluid - Multizone meshing | supercolli | ANSYS Meshing & Geometry | 2 | July 9, 2014 13:20 |
internal flow and external flow ? | Pathway0320 | FLUENT | 1 | November 17, 2006 03:37 |
Can 'shock waves' occur in viscous fluid flows? | diaw | Main CFD Forum | 104 | February 16, 2006 05:44 |
External flow field. | Moon | FLUENT | 3 | March 5, 2003 10:32 |
