[GAMBIT] How to draw a serpentine tube using gambit |
March 25, 2013, 05:46 |
Hi everyone,
I am a begineer with CFD, I want to draw a serpetine tube in 3D with gambit in order to simulate heat transfer with fluent. THis is a picture of what i want to draw : http://french.alibaba.com/product-gs...311689062.html Can you help me please ? thanks redagogo |
March 25, 2013, 06:44 |
Maxime Perelli
Rep Power: 41 |
you will use "sweep faces" tool with edge as "path"
http://aerojet.engr.ucdavis.edu/gamb...eom_volm_sweep But for that you need to create your path: in your case all edges, which will be merged before you will sweep your section (disk)
In memory of my friend Hervé: CFD engineer & freerider |
March 25, 2013, 07:40 |
thanks , I will try this technic
Why i need to material properties before fluid draw into the tube in CFD? | fruitkiwi | Main CFD Forum | 10 | April 3, 2012 07:21 |
Gambit== how to draw a 180 degree curved rectangular in gambit | zaolon88 | FLUENT | 0 | March 25, 2012 00:17 |
How to DRAW CURVE ON GAMBIT?? | teguhtf | FLUENT | 2 | September 16, 2009 03:25 |
how to draw camber line of an airfoil in Gambit | Muhammad Usman Qureshi | FLUENT | 1 | September 15, 2009 19:40 |
how to draw journal bearing fluid using gambit?? | zidane | FLUENT | 0 | March 8, 2009 12:40 |
