[DesignModeler] importing geometry from Solidworks to DM by.IGS
Old   April 7, 2013, 12:34
Default importing geometry from Solidworks to DM by.IGS
Moha
ahvz is on a distinguished road
I have an assembly file of my geometry from solidworks. when I save as .IGS file then import into DM the material still Solid wile I defined solid and fluid in solidwork. whereas, I can change it within DM but I must have import geometry with predefined solid and fluid by solidworks.
Where is my mistake ?
ahvz is offline   Reply With Quote
Old   April 7, 2013, 12:50
Sajjad Baraty
baratymm is on a distinguished road
Hi
1-you can define geometry type in DM easily.
2-you can test Save As STEP type.
I suggest No 1.
Thanks
baratymm is offline   Reply With Quote
Old   April 7, 2013, 12:59
Moha
thank you for reply,
I want to have this properties before importing to the DM. whereas, I defined solid and fluid for each part of assembly but I cant understand the reason why doesn't change in DM and still defied solid for two cases...
Old   April 7, 2013, 14:58
Sajjad Baraty
i think your license not work properly (may be).
Are you Save as Step format and export to the DM?
Old   April 7, 2013, 15:22
Moha
its work now
thank you!
Importing geometry from solidwork to ICEM CFD sahil sharma Main CFD Forum 7 September 2, 2012 14:01
[ICEM] Importing cambered airfoil geometry to ICEM CFD kotimari ANSYS Meshing & Geometry 2 July 16, 2012 15:44
Importing geometry from Pro E to ICEM CFD V5.1 sac CFX 2 January 16, 2006 08:38
Problem importing GAMBIT mesh to Ansys geometry David G. CFX 0 June 19, 2005 06:01
Importing Geometry from AutoCad Maurício CFX 2 March 22, 2005 08:41
