[DesignModeler] Gemoetry in Ansys DM anad Meshing
Old   April 16, 2013, 03:31
Default Gemoetry in Ansys DM anad Meshing
starter
sihaqqi is on a distinguished road
Hi
My geometry is two pipes intersecting at each other at 90degrees forming an L-shaped cylinder. When I make circles and extrude, I get this geometry but I can only define number of meshes at circle edges and junction curve. I want to define number of nodes longitudinally along the pipe but since using extrude command, I do not get longitudinal edges, I cannot do it. With defining number of nodes at edges, I can refine my mesh as much as possible but if I want to control refining making dense at junction and coarse along the length, it does not work to save computation time.
I have tried to draw the same geometry by sketching two lines perpendicular to each other but with revolve command, I can only draw one cylinder. When I want to draw second cylinder, it does not revolve. Can anyone help?
Regards
sihaqqi is offline   Reply With Quote
Old   April 16, 2013, 09:35
Paritosh Vasava
vasava will become famous soon enough
You can try with 'sizing' in the mesh control options. You can roughly calculate the size of the element and give it as a 'maximum'. I think this would work.
vasava is offline   Reply With Quote
meshing longitudinally
[ANSYS Meshing] Ansys Meshing Error on Generation resnik ANSYS Meshing & Geometry 3 February 14, 2024 23:43
[DesignModeler] Ansys Geometry n meshing Niru ANSYS Meshing & Geometry 130 January 14, 2017 11:44
[ANSYS Meshing] ANSYS Meshing vs. ICEM oborona ANSYS Meshing & Geometry 2 April 19, 2012 11:28
