[GAMBIT] Periodic cl
Old   April 26, 2013, 20:21
Default Periodic cl
drikzo
DRKIZO is on a distinguished road
Hi all,
I am new to CFD and i m doing a work on the inter cooling on a turbine blade, and i used gambit for modelling a 2D the geometry of the domain is shown in this picture :
I gave the following boundary conditions:-
1. Domaine inlet > pressure inlet
2. Domaine outlet> pressure outlet
3. The blade > wall
4. upper side> periodic
5. Lower side> periodic
After that i did export > mesh, but the file is not exporting successfully.
It is showing some errors with the
periodic boundary condition,
warn: boundary entity
periodic side shadow does not contain any valid entity and is not written.
error:
periodic boundary entities are not specified on the same boundary entity.
please help... what is the error and how can I resolve it...
thanks in advance
DRKIZO is offline   Reply With Quote
Old   April 28, 2013, 05:57
Jamal Foroozesh
jamalf64 is on a distinguished road
Do you ceate Hard Link between uper side and lower sid?
jamalf64 is offline   Reply With Quote
Old   April 28, 2013, 08:30
drikzo
yes i linked uper side and lower sid .
My problem gambit: when I do the two mesh faces (face 2 = solid, 1 = face fluid), after I export the mesh file and give the conditions to limit. it gives me movaises results in fluwent.
Old   April 28, 2013, 08:38
drikzo
I did not understand is that the problem in geometry creation of gambit, or bondary condition on fluent.
Old   April 29, 2013, 01:34
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
try to set both periodic BC as wall, and export.
If you don't get any error, then your problem comes from periodicity.
As Jamal mentionned, both periodic edges have to be linked (exactly same mesh)
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
[GAMBIT] periodic faces not matching Aadhavan ANSYS Meshing & Geometry 6 August 31, 2013 11:25
[ICEM] Periodic condition between ICEM and FLUENT Touré ANSYS Meshing & Geometry 0 August 5, 2012 17:00
HELP! Periodic Problem foxer FLUENT 1 June 27, 2012 08:00
[ICEM] how to define periodic for free type face in hexa meshing mingersai ANSYS Meshing & Geometry 0 February 5, 2012 01:55
[ICEM] how to define periodic in icem ? mingersai ANSYS Meshing & Geometry 1 February 3, 2012 17:46
