[GAMBIT] Meshing of a fluidized bed with a central jet
Old   April 30, 2013, 06:32
Default Meshing of a fluidized bed with a central jet
Musango Lungu
Musa is on a distinguished road
I am trying to mesh a 2D rectangular geometry of width 0.3m and height 1m equipped with a central jet of width 0.015m using GAMBIT with uniform quadrilateral mesh 5mm in both horizontal and vertical direction. See the figure attached. I manage to mesh the edges successfully but when I try to mesh the face I receive an error message saying "number of meshed edges of face does not allow using a scheme of map."
Musa is offline   Reply With Quote
Old   April 30, 2013, 08:36
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
I don't see any picture.
Anyway, the message you got, explains you that you are trying to mesh a face with quads which opposite edges don't have same interval count
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   April 30, 2013, 12:54
Musango Lungu
Hi max sorry here it isdpatil.PNG.
Old   April 30, 2013, 13:10
Musango Lungu
mAx the geometry has same number of intervals on opposite edges as I am using 5mm interval in both X and Y direction. Here is the geometry from GAMBITmesh.PNG.
Old   May 1, 2013, 01:36
-mAx-'s Avatar
Maxime Perelli
delete all upper edges mesh (only the top of your rectangle will be free from mesh), and let Gambit mesh them automatically.
Old   May 1, 2013, 09:17
ghost82's Avatar
Rick
ghost82 will become famous soon enough
Originally Posted by Musa View Post
mAx the geometry has same number of intervals on opposite edges as I am using 5mm interval in both X and Y direction. Here is the geometry from GAMBITAttachment 21316.
If it does not work, mesh each edge with interval count and not interval size, then check that the face has only 4 end-vertices, not less not more.
Daniele
ghost82 is offline   Reply With Quote
expansion of bed in fluidized bed achy7pch FLUENT 4 April 22, 2024 02:17
Fluidized bed modeling Kartus CFX 9 June 30, 2011 04:41
Fluidized bed simulation VS particle tracking windhair CFX 2 June 28, 2011 21:10
Fluidized bed simulation Siaw Khur CFX 3 July 28, 2010 14:42
Central jet injection in a fluidized bed Mike Main CFD Forum 0 April 26, 2002 15:14
