[ICEM] Automatic geometry preparation for hex mesh and circle curve splitting |
May 3, 2013, 08:58 |
Rep Power: 14 |
Hello.
I am learning ICEM CFD. And watch one interesting video (http://compteacher.ru/engineering/55...obuchenie.html) – video №4 (L-type geometry with 4 inlets). Author of this video make hex mesh very fast and easy. But one thing is not clear for me. When he starts work with blocking, he has a lot of predefined points on geometry. On circle curves there are 4 points like on figure №2 (not like on figure №1). Also he said that this point can be automatically calculated base on the feature angle and tolerance (if I hear correctly). So my question is how we can split circle curves to 4 arc curves automatically (like in figure №2)? And how prepare geometry for hex meshing – add additional points - also in automatic? I find some answers, but they need a lot of work to do 1. In ICEM make on circle curve 4 points and split this curve by them. (allot work on every curve) 2. In ANSYS DesignModeler – split edge command + split type: split by N=8 (this variant is a good one) It will be cool to do this preparation in automatic not by hand |
May 3, 2013, 10:38 |
Ghazlani M. Ali
Rep Power: 29 |
under geometry tab, click on create point ---» select "paramater along a curve". if you give it 0.5, the point will be created half way the curve... use 0.25 and .75 to get what you want.
May 5, 2013, 11:00 |
Rep Power: 14 |
Thanks for answer.
But I’m mentioned this variant (see my answer №1). To deal with this you should create 4 points and than splits. A lot of hand work, not cool! Using DesignModeler is much faster, but not really automatic. |
geometry preparation, split curve |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[ICEM] Using STL Data with ICEM CFD/AI-Environment | Shawn Givler | ANSYS Meshing & Geometry | 18 | March 11, 2019 13:03 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
Mesh distortion close to cylind wall-GAMBIT 2.2.30 | Mirek | FLUENT | 1 | April 15, 2006 17:22 |
How to mesh a circle by Gambit? | Zhengcai Ye | FLUENT | 5 | March 24, 2006 01:04 |
