[ANSYS Meshing] Inflation fails (non-manifold overlapping zone)
Like Tree3Likes
  • 2 Post By jrrygg
  • 1 Post By rgd
Old   May 9, 2013, 04:38
Default Inflation fails (non-manifold overlapping zone)
Anon
jrrygg is on a distinguished road
I have been struggling with an error in Ansys Meshing for quite some while, and I can't seem to figure it out. I have not found this error anywhere when searching for it, so I hope some of you can be able to help me out.
A picture of the mesh is attached, so you can understand my setup. I am modelling three Pelton buckets, and have tried to insert inflations in the side of the buckets exposed to the water jet (right side on the picture, only the left and middle bucket), with First layer height 0,1 mm and max 10 layers. I have also inserted face sizings in the same surfaces, and body sizing in a Body of Influence in the area around the buckets.
The error message is: Pre-inflation failed at face retriangulation with retriangulating non-manifold overlapping zone.
Has anyone sees this error before, or see any obvious problems with my mesh?
Thank you very much in advance for your help.
Best regards,
Jone
rgd and Kart379 like this.
jrrygg is offline   Reply With Quote
Old   September 13, 2014, 01:28
rgd
rgd is on a distinguished road
Dear Jone,
Have u found a solution to this problem?
I am currently facing the same thing
Kart379 likes this.
rgd is offline   Reply With Quote
[Commercial meshers] Mesh conversion problem (fluent3DMeshToFoam) Aadhavan OpenFOAM Meshing & Mesh Conversion 2 March 8, 2018 01:47
[GAMBIT] periodic faces not matching Aadhavan ANSYS Meshing & Geometry 6 August 31, 2013 11:25
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 10:52
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
Problem in IMPORT of ICEM input file in FLUENT csvirume FLUENT 2 September 9, 2009 01:08
