May 10, 2013, 20:36 |
Need help with volume meshing
Hi, I'm still a newbie to the ICEM and a new member to this forum and I have a problem with ICEM.
Currently, I'm trying to analyze a supersonic aircraft in cruise condition. Hence, I imported the model from STEP/IGES, enclosed it with a block-shape surface (as the farfield boundary), and meshes the surfaces (unstructured). I also created a body called FLUID to determine the air in this system using 2-point centroid method (the material point is located outside of the aircraft). Now, I want to know how do I volume mesh it with delaunay method ? I mean the important settings since the "help topics" doesn't enlighten things enough for me. If there's information which I haven't given, just ask for it. Thanks in advance. |
May 11, 2013, 07:57 |
Stuart
It will help people look at this is you can provide pictures and the mesh files. That way people can have a better idea of whats happening.
May 11, 2013, 10:31 |
I've surface-meshed the entire surfaces, the only thing left is the volume meshing of FLUID part. Last edited by badboyz31; May 11, 2013 at 10:43. Reason: added a few information |
May 11, 2013, 19:29 |
Well, I've seen both choices. However can anyone tell me the steps to volume mesh either with octree or delaunay ?
It seems that Delaunay has fewer options to choose from so I think I'll start with it. |
Problem of simulating of small droplet with radius of 2mm | liguifan | OpenFOAM Running, Solving & CFD | 5 | June 3, 2014 02:53 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
'Tetrahedral meshing has failed for volume...' | Murat | FLUENT | 5 | February 19, 2011 04:22 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
volume meshing | nikita | FLUENT | 1 | July 3, 2003 01:25 |
