August 14, 2013, 13:06 |
non positive volume
Rep Power: 13 |
Dear all,
I have two files here.One of them(before wall) is before defining the skin of inner pipe as wall and the other is after that(Faces are associated to surface for this purpose) and the only difference between this two files is this association. the first one will export to fluent successfully while the second one will export to fluent with warning of non-positive volume. Please help me. It 's made me confused. https://hotfile.com/dl/239611896/c32..._wall.zip.html https://hotfile.com/dl/239612371/894..._wall.zip.html |
August 14, 2013, 16:16 |
Ghazlani M. Ali
Rep Power: 28 |
You do have negative elements, here is why:
I circled in blue the edges responsible for that, don't worry about it too much, minor problem.... come back to us if you can't fix it |
August 15, 2013, 01:51 |
Rep Power: 13 |
Dear Ali,
Thank you so much for your reply. Please help me to solve it.I am a bignner.Actually I couldn't understand what you mean. |
August 16, 2013, 00:55 |
Rep Power: 13 |
August 16, 2013, 12:26 |
Rep Power: 13 |
no one can not help me?I have to solve my problem soon.
Please give me a solution. |
August 16, 2013, 12:48 |
Rep Power: 13 |
August 16, 2013, 13:10 |
#9 |
Rep Power: 13 |
Thank you so much.Would you please explain for me how did you improve it? I have to do it myself
Problem of simulating of small droplet with radius of 2mm | liguifan | OpenFOAM Running, Solving & CFD | 5 | June 3, 2014 02:53 |
mpirun interFoam very stable --> then blows up | ghadab | OpenFOAM Running, Solving & CFD | 3 | October 27, 2013 10:34 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 05:42 |
Non positive volume exist - How to find where ??!! | Cyril | FLUENT | 34 | January 2, 2013 08:41 |
FloWorks (Flow Express) Volume Goal Setting Issue | rbigelow | FloEFD, FloWorks & FloTHERM | 1 | November 16, 2009 01:32 |
