[ICEM] Meshing a pipe with 6 inlets
Old   May 29, 2013, 10:09
Default Meshing a pipe with 6 inlets
cs1
cs1 is on a distinguished road
Hey, i'm trying to mesh a Pipe with 6 injectors. The big injector ring will be put in the big pipe.
How do I mesh the 6 inlets and merge them with the big mesh of the pipe?
How is the strategy. I don't know how to proceed with the inlets.
Thanks for your help
http://666kb.com/i/cehm0dwlsjgjl7adm.jpg
cs1 is offline   Reply With Quote
Old   May 29, 2013, 11:53
Matthias Voß
mvoss is on a distinguished road
cut out the sectors (one segment per inlet, 60deg each), cut 2x circumferential (r=50% and r=75%, with r being your local radius, and the inlet @ 62,5%) and add a ogrid around each inlet.
supposing your want to have a hex-mesh.
you can also just block one segment and create multiple copies (saves time, since all the settings a copied from master-->copy automatically)
mvoss is offline   Reply With Quote
Meshing the pipe . Pavelko ANSYS Meshing & Geometry 14 May 30, 2013 23:10
[GAMBIT] Problem in meshing a pipe within a cylinder l14766 ANSYS Meshing & Geometry 7 May 14, 2013 17:24
How to draw 2 Inlets in 3D pipe mariam.sara FLUENT 16 January 16, 2012 01:14
Meshing a pipe joint for OpenFoam--Hex or Tet???? nileshjrane OpenFOAM 4 August 14, 2010 05:38
Meshing of circular pipe in CFX-mesh Fatnes CFX 3 March 27, 2009 06:29
