[GAMBIT] create face from vertex rows
Old   June 9, 2013, 17:47
Default create face from vertex rows
domenicoBUFF is on a distinguished road
Hi
Relativ new on mesh thing. Do you think it may be appropriate to create a face in Gambit (in the geometry phase) from a file containing the coordinates x,y,z of several points (becoming vertex in Gambit by reading the file), if the geometry to be described by those points is very irregular-shaped?
Also, how important is the order of the points, when selected to create the face (after importing the file), in such irregular-shaped case? For example, if I want two different rows of vertex (which will contribute to first create edges, then the face) close each other, then I need to select back-to-back those vertex that are actually close each other, correct?
However, what about the generation of the edges? In a complex geometry, the rows that are far each other (e.g. one of the first and last generated, but not exactly the first and last that directly contribute to edges) will contribute to the edges ''giving'' their first and last point, so I expect they will alter the geometry I actually want, correct?
Lastly, More rows, with less points each as a consequence, can better approximate the geometry I actually want, correct?
Many thanks, and best regards
domenicoBUFF is offline   Reply With Quote
Old   June 10, 2013, 07:13
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
did you try "create face from vertex rows"?
http://aerojet.engr.ucdavis.edu/gamb...e_create_vrows
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   June 10, 2013, 09:53
yes, thank you
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 12:55
Possible bug in blockMesh benru OpenFOAM Bugs 16 August 17, 2013 19:54
[DesignModeler] Create face from edges code_source ANSYS Meshing & Geometry 1 February 5, 2011 13:35
Creating a face 100s of of vertex points? David Banks Main CFD Forum 0 July 6, 2007 04:45
