[ICEM] Meshing of a Flat perforated plate (Zero thickness) |
June 11, 2013, 05:53 |
anonymous
I am trying to analyze the flow through a flat perforated plate kept at the middle of the duct.
Since it is of zero thickness, there will be connectivity issues when generating mesh. I am planning to make a structured mesh using blocking technique in ICEM CFD. I would like to know if there is a way to unpaste the surface of the perforated plate such that the plate has imaginary thickness and hence two surfaces: top and bottom. Thanks in advance! |
blocking, icem cfd, perforated plate, zero thickness |
Flow over a flat plate as an immersed solid | hamed.majeed | CFX | 4 | September 8, 2016 14:40 |
Flat plate analysis in cfx | hamed.majeed | CFX | 14 | February 4, 2015 07:07 |
[ANSYS Meshing] Meshing for flat plate immersed solid | hamed.majeed | ANSYS Meshing & Geometry | 0 | July 10, 2012 13:32 |
Need help on perforated plate with less than 2% open area | sosososo1114 | FLUENT | 9 | August 31, 2011 01:33 |
meshing over a flat plate | bhanu kishan | Main CFD Forum | 1 | February 7, 2009 14:45 |
